Need help with transmission airlines, old style 13 speed
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Vgarza32, Feb 28, 2018.
  1. Vgarza32
    Vgarza32 Bobtail Member
    19
    28
    Feb 27, 2018
    I have an old style 13 speed with 3 air lines. My original knob was the one switch on the side knob. Which allowed you to get from high to low and split with one switch. I’m trying to replace it will a new style air valve with 2 switches. That has 5 ports. Please help . I can get the 3 lines to work. And I don’t want to have to buy another custom switch
  3. beemergary
    beemergary Light Load Member
    229
    112
    Apr 11, 2014
    I just went the other way but had to modify it. Went from 4 lines to 3. Mines a RTO 14613 It needs air for low--No air for direct and air for overdrive (spitter) It got air for low from supply on trans. It got the air for the splitter from a tee on another line. Go to eaton fullers website-you can find all the air plumbing for shift knobs and transmission. The 5th port is an exhaust port not used.
  4. Vgarza32
    19
    28
    Feb 27, 2018
    My old knob received air from supply. Needed air for direct and od I’ll look more today
  5. beemergary
    229
    112
    Apr 11, 2014
    Just blow air threw knob and find out how it works.I actually had to drill a new passageway and plug another to make the chrome knob work.Good Luck
  6. Vgarza32
    19
    28
    Feb 27, 2018
  7. wore out
    wore out Numbered Classic
    15,382
    185,699
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    To switch to the newer knob you need to update the slave on the side of the transmission
    Oxbow Thanks this.
  8. Cgantt25
    Cgantt25 Bobtail Member
    Nov 2, 2018
    Hi can you post a photo of your shifter and the air lines in the transmission. Im trying to switch my shifter to thr older style chrome shifter also.
    Loggingrite Thanks this.
  9. beemergary
    229
    112
    Apr 11, 2014
    Its the chrome knob with L-D-OD button on side. If you take it apart it will give you No air in low-air in direct-and air in od. You plug the passage (JB Weld) for no air in direct and drill a new passage to give you air for Low. I just plugged the line at the tee where my old knob got air for the splitter. Once you know how things work live is pretty simple.
  10. Dobie mom
    Dobie mom Bobtail Member
    I have a 2017 Mack granite with a 13 speed. 2 questions. It's grinds everytime I split while only down shifting once I apply the throttle any idea why? And it came with an added air line with toggle switch. Do you know what it could be for? TX Sherri
  11. xsetra
    xsetra Road Train Member
    5,094
    6,941
    Aug 21, 2011
    Dobie mom start a new thread. You should get more replies.
    Good luck
