Need help
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by Jchase3188, Mar 12, 2021.
  1. Jchase3188
    Jchase3188 Bobtail Member
    Ok today my trailer landing gear wouldn’t go up so the company had someone come out and cut the legs off so now I have the trailer stuck connected to the the truck I want to know is this safe riding like this and could I get and trouble with landing gear in this position because I have a load that’s due coming from Texas to Iowa and they told me make delivery we will worry about the landing gear some other time
  3. Chinatown
    Chinatown Road Train Member
    74,923
    170,765
    Aug 28, 2011
    Henderson, NV & Orient
    If it were me, personally, I'd go with it.
    Maybe @Ridgeline has different solution.
    slow.rider and stillwurkin Thank this.
  4. JonJon78
    JonJon78 Road Train Member
    7,157
    39,339
    Jul 1, 2018
    What the Hell? :eek:
    John E Walker, jsnell and Dave1837 Thank this.
  5. LTL Bull
    LTL Bull Road Train Member
    1,561
    6,567
    Mar 12, 2020
    It’s fine to go down the road with no landing gear. Some cryo tankers didn’t even have landing gear as a weight savings, they used special cradles to support it if it need to be disconnected from truck. I’ve seen bottom dumps with no gear to. Not saying it isn’t odd what the company decided to do, but nothing unsafe about it. Inconvenient yes, unsafe no
    slow.rider and Chinatown Thank this.
  6. bad-luck
    bad-luck Road Train Member
    3,300
    6,064
    Nov 16, 2013
    Baltimore, Maryland
    Your fine to run it.
  7. pavrom
    pavrom Road Train Member
    3,185
    7,305
    Apr 29, 2012
    NE illinois
    ...if you dont disconnect the trailer - run forever
    slow.rider, ibcalm19 and Chinatown Thank this.
  8. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    I had the same thing happen. The road service came out cut one of the legs & kept it moving. Can't let one leg stop the progress. When one acts up "hop" on the other one:D:D
  9. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    Long as your shipper or receiver doesn't want you to drop the trailer no problem
    slow.rider Thanks this.
  10. Allow Me.
    10,677
    12,240
    May 28, 2009
    Rancho Mirage, Ca.
    Just put 2 stacks of about 10 pallets under each side if you need to drop the trailer, empty of course
    Speed_Drums Thanks this.
  11. MTN Boomer
    MTN Boomer Road Train Member
    1,157
    1,960
    Feb 4, 2019
    Airplanes do it all the time.
