Need Help!
Discussion in 'Flatbed Trucking Forum' started by 6wheeler, Jul 11, 2014.
  1. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    I picked up a truck load of straw in square bails in bags at a farm. The load has fallen off of the truck twice within 20 miles. 2 pallets. It was restacked on the flatbed with shrink wrap.
    Its not going to make it 250 miles from here. What should I ask the broker to do. It was shipped in a dry van to the farm. Anyone ever run into a load that you had to get off your trailer?
  3. BrandyJo
    BrandyJo Bobtail Member
    38
    12
    Jun 4, 2014
    It's only 2 pallets? Have you tried tarping it and maybe belly wrapping it? Are you strapping it tight enough? I've never seen issues with hay falling off.
    6wheeler Thanks this.
  4. Ruthless
    Ruthless Road Train Member
    9,106
    90,315
    Aug 28, 2010
    The City.
    Pics? Why is it falling off? Too loose inside the bags? Loosely stacked?
    Tarp it tight all I can suggest without seeing it for an alternative
  5. Chopswithafist
    Chopswithafist Light Load Member
    90
    36
    Feb 2, 2012
    West, TN
    I often haul square bales of hay myself, but I've never really had a problem. I would strap and tarp the hell out of it. At least keep the hay under the tarp, if it falls off at your consignee, blame it on the forklift operator!! lol
  6. 6wheeler
    2,696
    4,774
    Aug 30, 2009
    This is compressed 3 foot square bags on pallets stacked 8 feet tall. Just picture that but here is the bad part. It was delivered by dry van to a farm. The farmer did not like it so its being returned. Farm tractor can not end load 17 pallets in a van. That's why a flatbed was ordered when it should have been a van.
    Plan is to find extra pallets and break down the load onto other pallets to keep the stuff from tipping over. Also I will tarp it too.
  7. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Lots of shrink wrap, or banding plastic or metal, ratchet strap wraps around as banding... lots of options. Hell 40 bucks in duck tape. Gotta get creative to get the load off
  8. Ruthless
    9,106
    90,315
    Aug 28, 2010
    The City.
    Tarp it. Sounds like the only real solution. Is it inside the rails at least? Could you get some 2x4 8's stick em thru the rub rail n lever the stuff back on, punch a couple nails top n bottom of the rail to hold product in place and tarp over?
    sucks to spend the extra money and time. Sometimes you get farked. Know it for next time :|
  9. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    How did he get it out of the van?
    From what your describing, I would turned it down at the farm, made my apologies to the farmer and just canceled the load.
    Have them send another van, and just shuv everything in from the back. I've done a few hay loads and the farmer always shuved the load forward in order to load more hay at the back of my trailer. Pallets complicate things, but time is money and in this business if your stuck at a location, your not making money. I have no patience when it comes to loads that I have to struggle to keep from falling off. I mean from what your describing, its not a safe load to put on a flat bed. Personally I'd leave it alone.
    Hurst
  10. Ruthless
    9,106
    90,315
    Aug 28, 2010
    The City.
    Every hay load I've ever done was stacked on the deck, or jammed in a box....as the guy doing the hand loading I never stacked it so it could shift.
    money is to be made doing things that others don't, won't or can't. That being said, with broker loads some times they don't believe theirs any reason to pay more. That's a good time to cancel.
