Need help
Discussion in 'Peterbilt Forum' started by Stormbk, Aug 26, 2015.
  1. Stormbk
    Stormbk Bobtail Member
    17
    Nov 5, 2014
    I have a Pete 07 389
    Have to replace both stop/turn/brake light assemblies. My harness has 5 wires blue, red, white, black green. The new assembly has 3 wires black red green. Can anyone tell me
    How to properly hook these up so they will work?
  3. BooshWhacker
    BooshWhacker Light Load Member
    102
    82
    Dec 16, 2014
    Im guessing Black to Black, Red to Red, Green to Green, and stuff the other two wires out of the way. :Monkey wrench: :Screwdriver: :Wrench:
    lots of character Thanks this.
  4. QUALITYTRUCK
    1,810
    1,773
    Jun 14, 2009
    romulus,mi
    (2) of the wires are for right/left turn which also act as brake circuit.(1) marker light.(1) reverse light.(1)ground. Only way to know correctly is with test light or volt meter. If the assemblies only have 3 wires, that means that they ground through the mounting studs.(1)wire for turn(1)wire for marker(1)wire for reverse. Good luck.
