Need help
Discussion in 'Experienced Truckers' Advice' started by Beto6934, Mar 26, 2018.
Wipe it off, drive it atleast 200-500mi (whatever is enough to burn off moisture content) and recheck.
TripleSix Thanks this. -
Ask the shop that did the job.
Theres condensation and there's coolant. Not the same thing. If you are for not for sure, before you get too far down the road, take the valve covers off and look at the lifters. If there IS a problem, it will look like slimy mud coating the under side of the valve covers.
I completely agree. With the op's shining level of details he gave us, I kinda gave him like advice.TripleSix Thanks this.
Well check all that. Coolant is where it was this morning but theres still moist. Water temp I little higher than normal.
