Need high quality "RG6 coax cable?".
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Powell-Peralta, Jan 5, 2011.
  1. Powell-Peralta
    Powell-Peralta Road Train Member
    1,585
    240
    Jul 17, 2007
    i need the highest quality possible cable for cable use---in other words something that will screw into the cable outlet jack on the wall to go to TV and computer. i don't know if this is RG6 coax. But whatever it is called, i need it.
    Money is no object and only cable produced in the following countries is acceptable:
    1) United States
    2) Germany
    3) Japan
    4) Canada
    5) United Kingdom
    Thank you.
  3. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,471
    Nov 7, 2007
    Possum Booger, Alabama
    Please forward a cashier's check for $125 million dollars so I can get started on building the factory where I will produce this cable.
    Time is of the essence.
  4. rocknroll nik
    rocknroll nik High Risk Load Member
    4,490
    5,770
    Oct 18, 2008
    can't read the sign
    you can buy it at home depot by the foot
  5. slabsurfer
    slabsurfer Bobtail Member
    8
    Nov 18, 2010
    Denver, Colorado
    Look for a Cable-TV truck/installer and tell him you want a "jumper". Offer him $5 to make you one to length if he doesn't have one laying around that he's collected. They use better cable than the stuff you can find at the R-shack, W-mart or the big box stores. It's shielded better, cutting out the interference. You want a screw on fitting for best results. The slip-on connectors leak RF and your picture will suffer.
    Powell-Peralta Thanks this.
  6. AXE
    AXE Road Train Member
    1,651
    688
    Jul 2, 2010
    Chandler, AZ
    Having been a cable guy before truck driver (8.5 years) it is RG-6, we used quadshield with Comcast. As the poster up above said look for a cable truck and ask him/her to cut you a jumper. I had no problem doing it for people, some guys wouldn't. BTW screw on connectors suck, talk about leakage and noise in the line! You want the crimp on connectors.
  7. slabsurfer
    8
    Nov 18, 2010
    Denver, Colorado
    Sorry, I meant the fittings (F connectors) that are crimped on the RG-6 that can be screwed on the F-81's (barrels). I agree that the fittings you find that twist on the cable suck. I also hooked poles and pulled cable for some time.
  8. bbqguy
    bbqguy Light Load Member
    153
    82
    Mar 5, 2010
    East Wenatchee, WA
