Need ideas/pics for custom exhaust...kinda
Discussion in 'Kenworth Forum' started by cumminsISB, Aug 16, 2012.
  1. cumminsISB
    cumminsISB Light Load Member
    176
    10
    Feb 5, 2011
    D'Lo, Ms
    Not replacing my stacks as of now, but under the truck....the elbows, pipe and mufflers look bad and about to have holes in some spots. I have a 2005 W900l with a cat 550 acert c15 engine. It also has the 2 round mufflers under there. I want to go with one muffler but not sure if there is 2 under there for a reason. Also would like it to fit it one of the stock locations. Anyone ever went from 2 to one mufflers? How? and pictures would be great.
  3. ralph
    ralph Road Train Member
    1,112
    632
    Mar 1, 2009
    At The Key Board
    The two round mufflers under the cab are the "catylitic converters".
  4. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,116
    May 19, 2011
    I had the exact same thing under my truck. It is straight piped now, and no it is not loud in the cab at all. I can actually hear the jake brake now. I picked up about 3/10 in fuel mileage and lost alot of weight by getting rid of everything under there. No promises but I will try to get you a picture of it shortly. And if you think its something you want to do I can tell you exactly how I did it, it only took me about three hours.
  5. Oscar the KW
    12,246
    28,116
    May 19, 2011
    Ok, I took some pics and sent them to my wife. She is going to resize them and send them back so I can post them on here.
  6. Oscar the KW
    12,246
    28,116
    May 19, 2011
  7. freightrunner
    freightrunner Heavy Load Member
    722
    182
    Mar 25, 2012
    Georgia
  8. cowcatcher
    cowcatcher Light Load Member
    And cost about $5500.00 apiece !!
  9. flc120
    flc120 Heavy Load Member
    916
    122
    Jul 11, 2012
    Miami,FL (yeah i know :( )
    "F" them convertors lol ,take them off and sell the to venezuela or argentina they will buy them quick lol.... u should check with emissions regulations in your state. i stay in FL so i can run straights with a small muff and smoke out the heck as much as i want.
  10. BAYOU
    BAYOU Road Train Member
    2,847
    1,592
    Sep 23, 2010
    Beaumont,Tx
    So you just added a flex hose
  11. Oscar the KW
    12,246
    28,116
    May 19, 2011
    No, if you look close in this picture [​IMG] between the top clamp and the factory weld up the split, there is another weld that goes around the pipe, I cut the y-pipe there and removed IIRC around 4 inches and welded it back together. I also welded that strap on it that is bolted to the frame, which I later removed, it is not needed.
    To the left of that strap I welded an elbow to point towards the passenger side stack. The reason that I took out the four inches is so that you can keep the exhaust up high, it is not seen when walking around the truck like it is from the factory, and it also makes it very simple to get everything together when it is all at the same height.
