need info on 96 fl
Discussion in 'Freightliner Forum' started by ptours93, Nov 11, 2012.
  1. ptours93
    ptours93 Bobtail Member
    37
    4
    Sep 12, 2011
    orland park il
    i bought this truck with interior fire damage. basically the upper right rear corner and roof forward till upper valance was damaged.dash not damaged and valance was not damaged. it was an electrcal shortw/cab lite on rightside.now i don't know where the fuse box is need to find it to see if any circuits wiring is damaged.any help is apprecciated thanks
  3. richhawn
    richhawn Light Load Member
    117
    36
    Nov 8, 2012
    covington,IN
    should be a panel in the middle of the dash down by the floor in front of the shifter I believe.
  4. Rehab
    Rehab Bobtail Member
    39
    19
    Aug 16, 2010
    Festus, Missouri
    Three 1/4 turn screws hold that panel in. Prolly won't be any fuses in there. Mine was a 95 and all there were was relays. On the back of the panel should be a schematic as well.
  5. ptours93
    37
    4
    Sep 12, 2011
    orland park il
    thanks i'll check that out
