Need info on breather filter
Discussion in 'Freightliner Forum' started by me myself and I, Mar 7, 2017.
  1. me myself and I
    me myself and I Heavy Load Member
    733
    312
    Oct 5, 2009
    vernon hills,Il
    New ( to me ) '13 Cascadia with DD15. Leaking at the bottom of filter. Can the filter be replaced? How? What else would cause a leak there . Engine uses no oil, and runs fine.
  3. Animosus
    Animosus Heavy Load Member
    715
    2,807
    Dec 7, 2015
    SE Wyoming
    Yes the crankcase breather can start leaking, it's a centrifugal filter and if it locks up oil will just leak out the bottom. The entire assembly is replaced as one piece. 4 bolts and the line to the block. (Some have the speed sensor on them also, which is actually just a camshaft position sensor).
    About the only times I see leaks there are if it needs a crankcase filter, or excessive blowby caused by a cylinder kit failure. But usually if it's the latter it is a terrible leak, and you'll definitely already have coolant in the oil.
    QUALITYTRUCK Thanks this.
  4. mhyn
    mhyn Road Train Member
    4,255
    4,513
    Dec 29, 2008
    Northridge, CA
    on epa10 and higher engines locked breather throws fault code.
  5. me myself and I
    733
    312
    Oct 5, 2009
    vernon hills,Il
    And whole assembly needs to be replaced? Good idea...if you're Freightliner. Not so much if you're the owner
  6. mhyn
    4,255
    4,513
    Dec 29, 2008
    Northridge, CA
    I understand you. sad reality for owners..
  7. Animosus
    715
    2,807
    Dec 7, 2015
    SE Wyoming
