Need info RE: heavy-haul/oversize
Discussion in 'Ask An Owner Operator' started by 7mouths2feed, Dec 18, 2007.
  1. 7mouths2feed
    7mouths2feed "Family Man"
    1,186
    464
    Nov 29, 2007
    Jacksonville, AR
    Hi, After getting the obvious 2 yrs FB what is required to do heavy-haul/oversize. Specialized training? Driver permits? load permits? Is there a step system? IE- 25ton, 35ton, 50ton? or perhaps 10/12, 12/14, ....length of time driving each? .... Thanks All
  3. wallbanger
    wallbanger "Enemy of showers everywhere"
    The short answer is YES. If the Flatbed co you are working for does OS/OD, then you would have to ask about transitioning into that division.
    OR, you go to a company like Keen, that moves a lot of machinery (much of it OS/OD). They will give you specific training for machinery hauling, and provide (for a company driver) all the permits, chase/lead cars, etc. But even there you will start with the smallest stuff, and after proving you are a safe,responsible driver, will move to hauling larger freight.
  4. RAG
    RAG R.I.P.
    541
    4,922
    Nov 23, 2007
    Tonga
    Or you might conisder working for a local construction /grading/foundation/co. you will learn about many different types of equiptment.often times you will load it yourself
    i think keen is a no touch company. other than the chains and signes.
    you will not make as much $ as you would otr,but you sure would learn alot very quickley
    good luck o/w-o/s is just a ton of fun and pays great after a while
