need knowledge
Discussion in 'Peterbilt Forum' started by needtoknownow, Sep 21, 2013.
  1. needtoknownow
    needtoknownow Bobtail Member
    12
    Sep 14, 2013
    My 2004 pete 379 with a c-15 acert engine was put on computer, the results were Low voltage to acuator and low oil pressure to acuator. what does this mean and how do I fix it.
  3. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    Do you have the codes?
    needtoknownow Thanks this.
  4. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Yep need the exact code to narrow down the control valve or which intake valve actuator is malfunctioning. There is a series of them under your valve cover. One of the actuators can have a bad o-ring or the actuator itself is bad. The codes will reveal which one.
    Here's a helpful offsite thread.
    http://www.thedieselgarage.com/forums/showthread.php?t=113963
  5. needtoknownow
    12
    Sep 14, 2013
    peterbilt did not give me the codes they only told me what the codes said. thanks for the help.
  6. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    You have to go through the proper troubleshooting procedures for your specific codes. Acerts were known for injector harness failures that cause low voltage and low current codes to injector and actuators. Replacing the harness' will be about 8 hours if you've never done them before. They are also known for actuation pressure sensor failures. The valve actuator housings also crack and need to be looked at closely. Cat came out with an updated housing that thicker on the outer 2 stud holes.
    The harness issue has caused a lot of misdiagnosed actuators and injectors. How many miles are on them? Are they original? If you have no way to test them (an ohm meter does not work), I'd just replace them now, it's only a matter of time before they fail. I test injector harness' by totally disconnecting everything. I put 12 volts to each wire and measure voltage with LoadPro test leads to put a load on the each wire and look for a voltage drop. They almost always ohm out good when they are bad.
    Smellfunny Thanks this.
