I recently got this part change on my peterbuilt but ever since I feel my truck lost a lot of power? What can it be ?
Need name of part?
Discussion in 'Questions From New Drivers' started by JRod562, Mar 6, 2017.
The huffersmidt coincided with the vanderlilt at the wrong point.
The ratio is wrong. -
Welcome to the report but I have to ask if this is a joke? I thank it is an ISX and I am not an ISX guy. That part on the front of the crankshaft is blue on the top left. That color change starts at about 600 degrees F. Maybe someone did something incorrectly because you should never see that.
Then it looks like some special gas hatchet work, torch, or maybe that part just busted from not being heated and installed correctly. -
The think on the end of the crank that someone split like a log looks like a balancer to me. Could be wrong
The part isn't the problem, you should have the dealer put it on a computer and see what is popping up. A dyno should also be done to see if you are actually having a power issue.
