Need some advice on Sleeper AC not working!
Discussion in 'Ask An Owner Operator' started by Frghter Century 12.7 Detr, Apr 11, 2015.
  1. Frghter Century 12.7 Detr
    Frghter Century 12.7 Detr Light Load Member
    83
    27
    Mar 6, 2015
    Just took my Rig to my mechanic and I just bought ac compressor, two new expansion valves, seals, they did everything with the system charging and all that. The front ac works very good, the sleeper ac blows hat air, my mechanic was gone for the day so I could not get a hold of him. One ac line was cold and the other besides it warm. Called Freightliner and he told me it could be water heater control valve or heater switch on the sleeper control panel. What else can it be?
  3. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    AC? Sleeper? What are those? :dontknow:
  4. Dale thompson
    5,312
    45,288
    Nov 20, 2013
    commerce twp,mi
    if one line is cold and the other is warm that means the Freon is moving and doing its job so yeah my first guess is water control valve.
  5. DetroitSpecial
    DetroitSpecial Light Load Member
    76
    31
    Mar 18, 2015
    Sounds like the sleeper expansion valve needs to be replaced some have 2 one for the front one for the back,depending on the year you can just have one for both like mines,but newer trucks are located under the sleeper cab tight spot to get to.
    I only have one its under the passengers seat thats where my expansion valve,evaporator and heating core is located at.
  6. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Not sure on the Century,.. but on my Columbia my sleeper has its own condenser with its own lines for AC. It still uses the same heat exchanger on the front as the main AC,.. but the rest is independent of the main AC. Also has its own heater core and coolant lines for heat as well. Not sure how the control panel in the sleeper controls it all. But there is also an over ride switch on the front dash next to the main HVAC controls. Have you tried setting the front to max cool with the front fan to 100% and then set the over ride to see if it blows cool back in the sleeper? That should eliminate whether its in the control panel or not.
    I spent $2000 replacing my AC system, plus the HVAC control panel with all new parts when I first bought my truck. Expensive,.. but one thing they do well in Fla and thats AC work. LOL That was just over a year ago and have not had a problem since.
    Hurst
  7. Frghter Century 12.7 Detr
    83
    27
    Mar 6, 2015
    Yea, I just took it to Rush truck centers on HWY 60 Adamo in Tampa and they did change the expansion valve under the sleeper cab and the other on top of the air filter. I have a 06 century and after I posted this thread, I started the truck and tested both and it started working normally, very cold actually in this Florida heat.
  8. Hurst
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Your better off there then at Freightliner off 301.
    I go to J&M in Ocala for major work, and then I have a guy locally in Brooksville that does my PM and maintenance services.
    Hurst
  9. TaylorMade407
    TaylorMade407 Road Train Member
    1,328
    1,036
    Jun 30, 2009
    Orlando,FL
    Hurst I'm glad you mentioned J&M because I'm currently looking for a shop that can do the big jobs, motor, trans and rears. My cousin recommends diesel head group in Ocala also. But couldn't get anyone on the phone.
  10. Frghter Century 12.7 Detr
    83
    27
    Mar 6, 2015
    A lot of Owner Operators know how bad Freightliner in 301 service are. Parts yes, they give me good deals but my service I take it to Rush truck centers and the Manager told me that they just bought a lot of International service shops around the country.
