Need some help please
Discussion in 'Questions From New Drivers' started by RogerThat72, Mar 12, 2015.
  1. RogerThat72
    RogerThat72 Road Train Member
    1,787
    995
    Jan 30, 2014
    Looking for that peice on the antenna mount that's double sided and threaded so you can connect your cb antenna to it. Both sides on my new truck in driving are gone and I need it because I'm going to start being escorted on some of these heavy haul pieces soon. Just need the name so I can order them. Thanks
  3. MickTrucker
    MickTrucker Bobtail Member
    12
    Mar 12, 2015
    I had the same problem and looking for the same part!!
  4. Wanderer1
    Wanderer1 Light Load Member
    220
    119
    Sep 3, 2008
    Ask your daughter
    Google Bob's cb ,he has some hard to find stuff.
  5. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    I forget the exact thread size, but they're called a threaded coupler.
    I may be wrong on the threads, but something like 14 x 3/8 threaded coupler or 14 x 5/16" threaded coupler.
    EDIT: Make that 3/8" x 24 threaded coupler.
    RogerThat72 Thanks this.
  6. RogerThat72
    1,787
    995
    Jan 30, 2014
    Now, before I order. Is there a place to pick these up via walmart, Home Depot, tractor supply, lowes, or anything like that?
  7. RACEFAN
    RACEFAN Medium Load Member
    303
    172
    Nov 28, 2008
    RogerThat72, I found mine at a Loves in South Carolina. Not sure if they still carry them but that was about a year ago. It was with all of the cb equipment on the wall.
  8. KW Cajun
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    Very unlikely. Even most good hardware stores only have 3/8 x 16 (coarse thread) couplers.
    It's harder to find the 3/8" x 24 (fine thread) like you need. Mostly available at truck stops or cb shops.
  9. RogerThat72
    1,787
    995
    Jan 30, 2014
    10-4 thanks guys. Guess I'll have to take a ride and check then out hence I'm not over the road anymore. Appreciate it, stay safe.
  10. G.Anthony
    G.Anthony Road Train Member
    4,564
    5,952
    Dec 10, 2014
    Do a google search fro cb radio and equipment?
