Need some Help please
Discussion in 'CB Radio Forum' started by RogerThat72, May 23, 2015.
  1. RogerThat72
    RogerThat72 Road Train Member
    1,787
    995
    Jan 30, 2014
    Radio: Cobra 29
    Coax: clear 6 foot mini-8 with 16 guage stranded center conductor (x2)
    Antenna: browning 78 6 ft whip with coil at the bottom.(x2)
    So I hooked everything up and it powered on and as soon as I hit the key button on the mic it blew the fuse. It's a different power cord because I lost my other stock one so I'm using a 3 pin, 2 wire fused power cord 16 guage copper. Not sure if that has something to do with it. Fuse is 250v.
    Anyone have advice on what to do? It's a Mack truck.
  3. shortstack250
    shortstack250 Bobtail Member
    9
    5
    Jan 11, 2015
    Couple of questions what size fuse are you using, and has anything been done to the radio?
  4. Getsinyourblood
    Getsinyourblood Road Train Member
    1,273
    1,803
    Jul 5, 2014
    Retired. North Texas
    I am shooting from the hip, but I think fuses are rated by amp. I think standard amp rating is 3 to 5 amp for the power cord. I am pretty sure I have installed a 10 amp fuse before to stop blowing fuses with no problem.
  5. RogerThat72
    1,787
    995
    Jan 30, 2014
    I had it peaked and tuned a while ago. The amp is a 2A. I turn the radio on and they just literately spark and blow everytime.
  6. shortstack250
    9
    5
    Jan 11, 2015
    Well a peak and turned radio depending on how it was sure up requires a min 5 amp fuse. I would find a 7 amp. That's should cure your issue
    RogerThat72 Thanks this.
  7. RogerThat72
    1,787
    995
    Jan 30, 2014
    Thanks I'll try that out if if doesn't work I'll return and ask for more advice. I appreciate it.
  8. Getsinyourblood
    1,273
    1,803
    Jul 5, 2014
    Sometimes when the power cord is plugged into the back of the radio, it creates a 90 degree hard "pinch". Sometimes that hard pinch will cause the power cord to short out. If you continue to blow fuses, I would try using another power cord.(New)
    Mad Dog 20/20 Thanks this.
  9. rabbiporkchop
    9,681
    6,537
    Feb 9, 2012
    Wapwallopen, Pa
    Who tuned the radio? That's probably the source of your problem.
  10. Ougigoug
    Ougigoug Heavy Load Member
    971
    824
    Dec 4, 2012
    Planet earth
    2 amp fuse will keep blowing go bigger.
