Need some help please
Discussion in 'Questions From New Drivers' started by RogerThat72, May 23, 2015.
  1. RogerThat72
    RogerThat72 Road Train Member
    1,787
    995
    Jan 30, 2014
    i posted in the cb forum but that forum is dead and takes forever to get an answer....so here goes nothing.
    Radio: Cobra 29
    Coax: clear 6 foot mini-8 with 16 guage stranded center conductor (x2)
    Antenna: browning 78 6 ft whip with coil at the bottom.(x2)
    So I hooked everything up and it powered on and as soon as I hit the key button on the mic it blew the fuse. It's a different power cord because I lost my other stock one so I'm using a 3 pin, 2 wire fused power cord 16 guage copper. Not sure if that has something to do with it. Fuse is 250v.
    Anyone have advice on what to do? It's a Mack truck.
  3. 062
    062 Road Train Member
    6,233
    33,549
    Oct 20, 2013
    What amp is fuse?
  4. Moosetek13
    Moosetek13 Road Train Member
    14,726
    18,548
    Nov 1, 2010
    Burnsville, MN
    A 250V fuse, for a 12V application?
    A non-stock cord.
    What is the AMP rating of the fuse?
    Why not just buy the right one? They can be found in any truck stop or CB shop.
  5. RogerThat72
    1,787
    995
    Jan 30, 2014
    Idk I did buy it in the truck stop its a road pro. When I opened it the fuse says 250v
  6. 062
    6,233
    33,549
    Oct 20, 2013
    It should have 1A...2A on the fuse. The number is the amperage,if that's a stock 29. Then a 3A or three amp fuse should do,but if it's moded may need a five or seven.
    RogerThat72 Thanks this.
  7. RogerThat72
    1,787
    995
    Jan 30, 2014
    I've had it peaked and tuned that's all. Might have to hit a cb shop. I appreciate your response
  8. 062
    6,233
    33,549
    Oct 20, 2013
    You can try a five,if it still blows. Then most likely a short in the final or audio stage.
  9. RogerThat72
    1,787
    995
    Jan 30, 2014
    Yup keep blowing 2A so I'll shop around until I don't blow any lol
  10. RogerThat72
    1,787
    995
    Jan 30, 2014
    I was thinking of getting a new radio what would you reccomend? It's now blowing the fuse if I just turn the radio on so idk
  11. 062
    6,233
    33,549
    Oct 20, 2013
    Don't know much about the new radios. I tend to run equipment until it can't be fixed for a reasonable price. Right now I'm running a 99v that's about seventeen years old,with a rk56 that's probably twenty five plus.
