Here's the scenario. I have a 2001 International with a DDEC 3 and (I think) 370 HP. Maybe 430, but I doubt it, since we're down to about 25 mph on any significant hill. Almost a million miles on her, but inframed at 680,000 and both differentials have been rebuilt. 10 speed, never been opened. Outbound loads are just about 80,000 lbs (tri axle trailer), inbound somewhere around 69,000. Running basically from Pocatello, ID to Vancouver, BC and back. We see some ups and downs.
In about six weeks, I'm going to bump the registration up to 90,000 so I can run the extra weight. Cheaper than running the truck more often, and easier to keep to a weekly schedule. But, I have a wimpy little truck, but one that is paid for, in tip-top shape, and light weight.......
Since we are always bumping into the log-book, I want to keep the drive time the same, or even a little less. Looking at two mods for the truck. 1) What is the best way to bump the HP on the motor, without running the risk that the driver cooks the thing on the first pull up Cabbage? ECM tuner? If so, which one? 2) at which point is it worth looking at swapping that 10 speed for another transmission, and which one?
Need some help with getting ready for pulling heavy loads
Discussion in 'Ask An Owner Operator' started by Accidental Trucker, Jun 5, 2015.
i ran that much and some on a similar hp detroit with a 9 sp in my freight liner. it will get the job done if your not worried about being the first to the top of a hill. might need to upgrade the cooling system i had some trouble keeping coolant temps down pulling long grades in hot weather. it was manageable with a new larger radiator and air to air. but on a 100 deg day sometimes you would still have to back out of it a bit and turn the ac off on a real long hard pull. i never did up the hp on mine it got the job done as is. i wanted to put a pyro in it before even considering bumping the hp and i never put a pyro in it. now i bought another truck better speced for the work i do.
Accidental Trucker Thanks this. -
It should not be that hard to have the motor turned up to give you more horsepower. In 1996 I got a brand new Pete with a 3406E that was set at 355 horse and after 6 months or so we had it turned up to 475 with no hardware modifications. I know an owner operator with a 430 detroit that just had it overhauled and after the break in period he is going to have it turned up to 500 just by having the dealership rework the software. You might even see some improvement in fuel milage because the motor wont be straining as much.
Jumbo, are you talking about swapping out the ECM for a higher HP version? What's the benefit compared to a after-market tune (say a Bully Dog) or even a PP powerbox?
If it were me I'd upgrade the turbo and just do a mild ECM tune. If you keep it simple you shouldn't have to worry about getting it hot. I have a 10 speed and a 12.7 set at 500 with a Borg Warner non-wastegated turbo and I run 85-90000 pretty regular with a cow trailer. I'm not the first one there but I'm putting more in the bank.
Pyro and boost gauge are on the project list. Panel mounted units or is a scan gauge more useful?
scangauge will only read it if there is a factory sensor. There will probably be boost, but may not be pyro.
Might want to check the torque rating of your transmission before turning up the engine. For example, my rockwell/meritor can only handle 1550 torque in the top 2 gearsAccidental Trucker Thanks this. -
Learned something today..... (finally
) My mechanic hooked up his reader to the truck, and it was set to 430 HP on the cruise, but only 370 on the throttle. Apparently that was a common setting, to encourage drivers to run on the cruise. Set both to 430, so that should help climb hills quite a bit. He's looking for a used 500 HP ECM, but not sure if that is helpful without injectors and turbo to match? Going to run a couple of trips and see how it runs with the new settings, before pulling the trigger on those mods.
Tranny will get load moving without putting a lot of pressure on motor/rears. The go increase will make life easier for the engine and reduce egt and coolant temps. The best way to keep your truck running smooth is check for larger radiator and air cooler,then it will all work together.
I use to run a 2000 Kenworth T800 pulling tri-axle trailers grossing 102-112000 daily. Had the 12.7 set at 430hp 10spd and 4.33's in the rears and it was a solid little work horse. The 4.33's made all the difference keeping it in the powerband and still got 6mpg.
