Need to ground a steel antenna on a Cascadia. General disarray.
Discussion in 'CB Radio Forum' started by cdcii, May 3, 2014.
  1. cdcii
    cdcii Bobtail Member
    18
    4
    Sep 1, 2012
    Albuquerque, NM
    Bird perch mount is not doing the trick. Brand new Uniden 880 Bearcat, large coil steel antenna by K40, and a decent coax that I'm stretching out (so it will stop coiling--that helped bring the swr down some.
    Where do I conect, and what's the best way to get a solid ground? SWR readings on the internal climb from 5-12 from 1 through 40. This is assuming I have the meter calibrated properly (digital readout--do I go past the CAL mark, or just below it? Where the bar above it is flashing?).
    Any help/direction is welcome. Thanks.
