Need to repair this axle, can you help me find the right way?
Discussion in 'Ask An Owner Operator' started by feldsforever, Jul 28, 2021.
  1. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    And help me decide how to fix this?
    I can see it is a gasket leak of some sort.
    Both axles on the drivers side is showing this. Is it as simple as checking the torque on the nuts? 16274744893601867706383.jpg
    D.Tibbitt Thanks this.
  3. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Is it something I can do at home?
  4. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Axle flange gaskets, torque nuts with torque wrench clean stain with brake cleaner. Run it if seeping is still present then remove axle shafts clean off old gaskets and install new flange gaskets
    retorque. Rotate the full hole in hub to 3 or 9 o clock position and refill hubs with
    75/90 weight synthetic. You will lose a little when you pull axles
  5. Big Road Skateboard
    6,646
    37,320
    May 2, 2021
    Easy fix, but replace those nuts with locknuts, every time the axle is pulled
  6. feldsforever
    1,453
    1,440
    Nov 22, 2019
  7. jason6541
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    What ever you do, do not use silicone sealer. Use some scotch brite and solvent to clean gasket mating surfaces. Use a torque wrench after nuts are just barely snugged up. Not a impact, you can pull the studs from the aluminum hub
    Easy job and won’t take long if you do have to change gaskets. Have fun
  8. bad-luck
    bad-luck Road Train Member
    3,357
    6,206
    Nov 16, 2013
    Baltimore, Maryland
    Tighten all the nuts. Spray off the oil with carburetor cleaner or starting fluid. See if that fixes your problem. If not you will need a new gasket.
    Final Drive and feldsforever Thank this.
  9. bad-luck
    3,357
    6,206
    Nov 16, 2013
    Baltimore, Maryland
    1st I have ever heard for using lock nuts on an axle.
  10. Big Road Skateboard
    6,646
    37,320
    May 2, 2021
    I've made hundreds of service calls for leaking axle gaskets. Most of those were because wheel seals were replaced, and either old lock nuts were reused, or lock washers not replaced.
  11. bad-luck
    3,357
    6,206
    Nov 16, 2013
    Baltimore, Maryland
    Ok, I am not saying it's a bad idea, I have never seen any nor heard of it being done.
