Need turn signal wiiring diagram for 2011 freightliner columbia
Discussion in 'Freightliner Forum' started by Bill8220, Aug 26, 2014.
What are the symptoms? Do they work with the trailer disconnected? When you put on the right hand directional do both the right and left dash lights light up?
With trailer disconnected, when you turnon right turn signal or flasher breaker kicks off. Brake lights work and all other lights work. Disconnected light plugs and turn signal switch, direct short in wire.
If have a 2 tail light system and your brake lights work, I'd say that your issue is in the front or side signals. Gives you 1 less wire to trace. If you have 4 tail lights, that wont help.
Bill8220 Thanks this. -
I have a two tail light system. I disconnected the plug on the right side of cab, the short isn't in the side or front signals. It is inside the cab wiring harness, that is why I need a wiring diagram. The short is under the dash panel between the turn signal switch plug and the cab plug. thank you for your help.
I would be surprised if the problem were inside. Wires usually chafe and rot away outside. Have you traced all the wires outside back in? I've seen wiring diagrams for trucks and you will not like what you see
Sorry, I don't have access to any Columbia's to get wiring. It wont help you now, but for future reference, go to www.accessfreightliner.com and register. They give out free access to parts, wiring diagrams and some service info to owner ops. They may make you verify ownership and it'll take a week or two to get.
