Needing our equipment moved... bypassing load boards?
Discussion in 'Ask An Owner Operator' started by aogmanagement, Aug 31, 2021.
  1. aogmanagement
    aogmanagement Bobtail Member
    To keep things as basic and straight-forward as possible: We do not own a tractor/trailer and have worked with a couple of brokers in the past to get our gear from location to location. I'm just wondering if it's possible to find owner/operators without going on a load board or through another broker for some of our movements. We don't send our gear out very often, which is why we haven't subscribed to the load boards as of yet. We currently have gear in central Florida that would require 2 53' loads to the west coast next month.
    Any suggestions or advice before we sign on to DAT or similar?
  3. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,058
    Nov 18, 2014
    Land of local
    Post some more details to get more accurate info. Flatbed or van?
  4. Capacity
    Capacity Road Train Member
    1,499
    3,118
    Jul 28, 2019
    Neenah Wi
    Gear? Are we talking about Backline AV gear.
  5. PoleCrusher
    PoleCrusher Road Train Member
    7,503
    82,190
    Aug 26, 2014
    LLMF
    Trucking companies like Landstar, Bennett, Admiral Merchants, Mercer and some others are all o/o that are leased on. You can call these companies yourself and ask for quotes for your loads.
    Just be specific and adamant with them that you do not want them to broker out your loads.
    Speed_Drums Thanks this.
  6. ZVar
    ZVar Road Train Member
    10,911
    23,828
    Sep 10, 2010
    Flint, MI
    Aren't those companies acting as a broker themselves?
    mitmaks Thanks this.
  7. Truck N' Roll
    Truck N' Roll Bobtail Member
    12
    16
    Aug 18, 2021
    What kind of gear? If it's entertainment, I'm your guy!
    feldsforever Thanks this.
  8. aogmanagement
    Thanks for the replies thus far. We specialize in aviation conferences and trade shows. The majority of our equipment is portable air conditioners, ground power units (electric), and other electrical components/equipment (cables, distribution panels, etc). Equipment weight for us in a 53' dry van is typically in the 30-35k lb range.
  9. PoleCrusher
    7,503
    82,190
    Aug 26, 2014
    LLMF
    No. They may broker some loads when they do not have capacity, or when the rate is so cheap they can't get one ofntheir own O/Os to take it. But they are not primarily in the business of brokering freight.
    ZVar Thanks this.
  10. Midwest Trucker
    5,889
    21,240
    Aug 31, 2018
    It’s going to be expensive no matter what. Especially since that gear has to come back to Florida I’m assuming.
    Was your experience with brokers in the past less then desirable? Like you said, you can sign up to DAT but obviously your no expert on vetting carriers. However, that doesn’t mean it would go bad.
    The big carriers IMO I’d find hard to trust since your freight isn’t important to them like it is to you. So, I can see how you would prefer working with a small independent company.
    Wish I could give more advice. We’re not allowed to solicit business on this forum or I’d see about helping out. Maybe there is a smallish local company around you with 10 to 25 trucks or something that goes west regularly.
