Needing Some Serious Helpful Advice....
Discussion in 'Questions From New Drivers' started by TKR117, Jun 18, 2015.
  1. TKR117
    TKR117 Bobtail Member
    20
    13
    Jun 2, 2015
    Like the title says, I'm currently at Schnieder National In Charlotte NC for my orientation... I am a active duty veteran and currently serving in the national guard and am 88M Motor Transport Operator for them, needless to say I have NO manual transmission experience except for cars and motorcycles. I'm on my 3rd day and this truck is kicking my ### up one side and down the other. I get it to shift up through the gears but downshifting is pretty much pointless for me, my instructor wants to keep longer before releasing me to my TE and I know why... So if I continue down the path I'm on and eventually pick this thing up and run with it will I be able to preform my job correctly and not have my ### whooped at the end of everyday and get so frustrated to the point of wanting to quit and throw in the towel OR do I just need to go ahead and realize this and stop where I'm at and switch to a company with automatics? Please don't degrade me or my instructor I'm just wanting to know what I need to do now because today has been absolutely horrible for me including my military time too.
  3. thelushlarry
    thelushlarry Road Train Member
    3,023
    8,999
    Jan 9, 2012
    glasgow ky
    The main trick to down shifting is to lug the engine before trying to down shift..Just remember you can do it! It is all in the feet.
    TKR117 Thanks this.
  4. Hyweighman
    Hyweighman Medium Load Member
    517
    659
    Dec 29, 2011
    Pensacola, FL
    Don't quit. Only quitters quit. Keep at it. Ask for more practice. Learn to match rpm to speed. Good luck and thanks for you service
    Sneakerfix, dog-c, okiedokie and 2 others Thank this.
  5. Vilhiem
    Vilhiem Road Train Member
    3,992
    10,904
    Oct 6, 2014
    It's not a bad thing... You're right that shifting will come to you eventually, it's one of those things that's "easy to learn but hard to master."
    Some of the million mile vets have their off days and grind a couple gears. So don't expect perfection all the time.
    Don't know if that helps, but getting the gears just takes practice. No reason to give up.
    Oh, and FYI... Sni would've booted you if they thought you couldn't get it down. So you must be doing better than you think.
    (Side note: search the threads...there are countless questions from other drivers about up and down shifting. We've all been there.)
    Oh yeah... I happen to be in the Charlotte area until the end of the week. I plan to drop by and at least get fuel. If you're there I'll buy you lunch or something eh?
    TKR117 Thanks this.
  6. 6daysontheroad
    6daysontheroad Medium Load Member
    462
    698
    Dec 15, 2012
    North of the Rio Grande
    You're going to have good and bad days no matter what you do, but especially in trucking. Downshifting takes a little more time and practice than up shifting does. It's a matter of co-ordinating your rpms with going to neutral then dropping to the next gear. You might try using the clutch to go to neutral then release the clutch and rev to whatever the shift point is for the lower gear. Don't get discouraged after a little time and practice you'll get the hang of it and will be able to hit gears better than any automatic.:D
    TKR117 and Vilhiem Thank this.
  7. vavega
    vavega Light Load Member
    295
    177
    Oct 13, 2009
    maple shade, nj
    first off, thank you for your service!
    your training tells you not to give up, and believe me after a frustrating day like the one you've had it's easy to entertain the idea. your tired and feeling like an idiot but know it will get better with practice and time. so no, don't go the automatic route. stick with it, if nothing else so you can conquer downshifting and know the feeling of working hard for something and finally succeeding.
    then come back here in a couple days and start a thread titled "I DID IT"
  8. Vilhiem
    3,992
    10,904
    Oct 6, 2014
    Oh yeah... Being able to do manual opens up quite a few fields (someone please confirm?) that you couldn't do in an auto...
    Not to mention, from what I saw when I was in your shoes in orientation... SHIFTING IS A WANTED SKILL.
    If I see you at some point I'll elaborate on that. If not then you can search my posts, I'm sure I've talked about the "Grind me a pound" guy on here before.
    TKR117 Thanks this.
  9. KMac
    KMac Road Train Member
    3,427
    3,067
    Jan 26, 2012
    Waxahachie, TX
    I am a former 64C... That was 88M before it was cool!
    I learkednon a Vietnam Era 5 ton, 5 speed synchro, nothing like these, and then went to permanent duty on an M915... Back when it was Semi Automatic, then went to an M931 fully auto, then made the transition to an Eaton.
    You can do it, just takes some coordination. And practice.
  10. TKR117
    20
    13
    Jun 2, 2015
    Vilhiem, Thank you for words of encouragement and the motivation to stick through with it. Right now is just my crawl phase I guess and I'm more than likely expecting to much out of myself all at one time. I'm in the area until Saturday at some point and if you happen to stop by at the OC it would be great to meet with someone new and maybe get a different perspective on this.
  11. FozzyNOK
    FozzyNOK Road Train Member
    2,460
    3,789
    Jul 18, 2007
    Oklahomistan
    Try this (Your instructor may or may not agree).. First of all.. Downshifts can ALL be made at the same RPM range. Its a math problem. At first use 1000 RPM.. DRAG the RPM down using the brakes.. Effective braking is one way to get in control of the downshits... DRAG the RPM's down.... once at 1000, tap the clutch and move to neutral... when your foot is OFF the clutch, QUICKLY "wick" the RPMs up.. you only need to raise them 400 or so RPM to get into the next lower gear.. Think of a flight of stairs... Upshifting is always easier cause your going down stairs,, gravity does the work.. When you are climbing the stairs (downshifting).. you have to raise your foot (RPM) high enough to get to the next step.. Too low? You hit the front of the step and don't get anywhere.. too high? You don't get on the correct step.
    You also have to have your foot off the clutch to make the whole thing work. If you have your foot buried in the clutch, you are not matching the engine / drive train / road speed. Think of the drive train.. the engine is always moving.. the transmission is moving when the clutch is released.. (even when out of gear). To get the truck into gear you have to match the transmission to the road speed (zero).. so the clutch brake allows you to slow the transmission to meet the road speed (zero). Once you release the clutch.. the wheels start moving the speed of the wheels and transmission are now "synchronized"... if you now push the clutch in.. the transmission stops moving and you cannot get the truck into gear.. there is no way to match the now not synchronized wheels with the stationary transmission..
    Without a whiteboard.. this is probably confusing as hell... sorry
    You have to control a lot in a little bit of time.. it will come to you, but its nothing like the cars and bikes.
