Needle in a haystack?
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by RubberDuck473, Apr 5, 2023.
  1. RubberDuck473
    RubberDuck473 Light Load Member
    189
    324
    May 2, 2021
    Texas
    Was just wondering if there are any non-mega, sub-500ish truck companies out there (like FCC or Magnum) that have a lot of freight that runs the lower corridors (e.g. I-10/I-20/I-40 from Cali to the southeast GA/NC/SC region) and from the PNW down to the south/TX region that hire out of Texas. Not necessarily JUST those areas, like a "western 11" company, but someplace where it's not uncommon to get 2 or 3 of those type of runs every month or so. Preferably dry van or reefer. Seems like the more searching I do, the more I think my only/best option is to buy my own truck and go wherever I want lol.
    Thoughts?
    D.Tibbitt and RockinChair Thank this.
  3. Eddiec
    Eddiec Road Train Member
    2,294
    3,517
    Feb 2, 2015
  4. Chinatown
    Chinatown Road Train Member
    76,902
    179,530
    Aug 28, 2011
    Henderson, NV & Orient
    Speed_Drums Thanks this.
  5. lual
    lual Road Train Member
    5,105
    9,255
    Oct 22, 2020
    SW Georgia
  6. DRTDEVL
    DRTDEVL Road Train Member
    1,706
    3,428
    Jan 27, 2013
    Austin, MN
    AN Webber out of Kankakee IL does. I'm not sure about their entire hiring area, but they hire out of west Texas for sure. They haul PACCAR parts from the PNW to TX, and they run AO Smith water heater loads from El Paso to various drop yards in the SE and Midwest for their local/regional guys to deliver. They fit at the smaller end of the size at 130-ish trucks, but have been around long enough to have a 5-digit DOT number. I believe their terminals are in Kankakee, El Paso, Pleasant View, TN, and McBee, SC.
    lual Thanks this.
  7. D.Tibbitt
    153,222
    maybe check out trius trucking . they run reefer trailers. never see them north of i40.. they are based out of cali.
    never worked for them or even talked to any of there drivers.. just see their trucks running i10 and i40 on the regular
    Trius Trucking Inc | NOW HIRING CLASS A DRIVERS | California
    lual Thanks this.
  8. AZtruckdriver
    AZtruckdriver Light Load Member
    57
    68
    Aug 22, 2024
    Trius is a great suggestion . When I was there I’d pick up produce in CA or AZ and deliver to Tx or somewhere in the southeast usually(90%) then you pick up chicken in TX ,LA or AR and deliver back to AZ and Ca . Newer trucks governed at 75-77 depending on the truck ,some run faster mine was set to 85
    Home terminal is in Fresno , they also have a yard in Phx and some yards in Tx . Pretty good gig if you don’t mind reefer work , the owner Nick will run you if want the miles / money
