New 2014 T800 Kenworth
Discussion in 'Kenworth Forum' started by mapleleafs35, Oct 14, 2013.
  1. mapleleafs35
    mapleleafs35 Bobtail Member
    Hey guys, first post and thought I would ask some questions to people with experience. Gonna be pulling the trigger on a new T800 Kenworth soon. I run a farming operation and will be pulling a tri axle grain trailer which will go 100 miles from home at the most..and pulling off of soft fields and yards is more of a concern than fuel economy. Dealer is trying to get me into a Paccar 500 mx instead of the ISX. Advice? We have a 3500 RDS Allison in our tandem grain truck and it has been awesome to say the least. Was wanting to try the new TC10 TS Allison in this truck but again the dealer is pushing ultra shift plus 18 speed. Advice? I really like the truck look as compared to the new 880 and was gonna go full lockers, 4.10, 46 rears, 205 wheel base, day cab...anyway...you guys must have been running the DEF systems for a while...are they improving in reliability? Any info appreciated
    Thanks,
  3. pcfreak
    pcfreak Heavy Load Member
    835
    385
    Apr 22, 2007
    Alberta, Canada
    I'm not familiar with the Paccar motors, so I'd say go for the ISX. I'm assuming that in the field, you will run into soft spots. For that reason, I would never use the automated manual trans. If you need an auto, stick with the Allison. The auto shift is not capable of the quick shifts you can do in a conventional standard trans. It would be stuck in first gear until you get to a solid area. I used to work for a manure spreading outfit, and have seen my share of soft fields and areas to get stuck, and if I needed to shift for any reason, I had to do those real quick throttle blips and a quick move with the shifter. I don't think the auto shift units can pull that off.
    Oh, I run a 2014 Pete with a 450 ISX with DEF, and I have not had any issues with it.
  4. Cat sdp
    Cat sdp . .
    20,886
    72,324
    Apr 8, 2012
    Orion's Belt
  5. The Challenger
    The Challenger Kinghunter
    7,127
    3,367
    Dec 22, 2007
    East Central FL
    Heres a video of the new TC10.
    http://www.youtube.com/watch?v=ip1C6AEo3f8
    If it were me, id avoid of paccar mx and go with the cummins ISX. Knowing the conditions, id opt for an 18spd. As PCfreak mentioned, if you need an auto, go for the allison. My old company ordered a new one and hasn't had any problems with it since they got it.
  6. ReeferOhio
    ReeferOhio Medium Load Member
    596
    557
    Nov 29, 2010
    MX with the ultra shift plus, depending on weight the 18spd might be over kill. You tube eaton's web page you will be impressed the the MXP.
  7. IH Branded
    IH Branded Medium Load Member
    412
    104
    Jun 4, 2013
    Great Lakes area
    Pretty good to be able to justify a brand new rig for 100 miles. You probably run a lot of grain so happy for you.
  8. Lone Ranger 13
    Lone Ranger 13 Road Train Member
    1,542
    1,298
    Sep 27, 2012
    Asheville, NC
    I think I would consider a glider built with a non-egr engine and avoid the new emissions issues. It will most likely be more reliable and cheaper to operate and maintain.
  9. Farmer Jon
    Farmer Jon Bobtail Member
    8
    Feb 2, 2014
    Pender Nebraska
    We just ordered 3 t-800s and our dealer in Sioux City Ia said to stay away from the Paccar. Especially in farm application. They have had nothing but trouble. Defiantly go full lockers. We got the 550 cummins with 13 speed.
