New Altenator problems
Discussion in 'Peterbilt Forum' started by sdwndr5464, Apr 22, 2013.
  1. sdwndr5464
    sdwndr5464 Guest
    Changed alternators 2wire shielded ground to a 3 wire and I am overcharging constant 130 amps I am afraid ill melt my batteries, any one know. The old one has 2 posts Pos +.And neg.- shielded .. .The new has pos.+ .I. and R. Posts I am stumped....
  3. snowwy
    snowwy Road Train Member
    20,553
    13,281
    Jul 6, 2009
    you won't melt the batteries. you'll just cook the acid out of them LOL.
    and if your lucky, they might even burst. (had that happen once).
    there was another thread. something about grounding a 3rd wire.
    someone will come along eventually with an idea for ya.
  4. 04 LowMax
    04 LowMax Medium Load Member
    440
    250
    Feb 3, 2013
    Alberta
    Sounds like you don't have your reference voltage wire connected, telling the alternator to cut out? Whatever you do, don't run it like this until you get the situation rectified.
    CondoCruiser Thanks this.
  5. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    What color are the wires? How do you have it wired to the new alternator compared to the old alternator.
    On a Pete the "R" is usually connected to the Tach as a pulse reference signal or feeds a dummy light. The "I" wire or ignition excite wire usually goes through the ignition switch and connects with the backside of the dummy light which acts as a resistor and signals the internal regulator (ignition hot).
    It sounds like you are going from a shielded ground to one that is grounded through the housing.
    Any certain reason you changed alternator types?
    We can make it work. You might have to run an ignition wire.
  6. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    That third terminal is a voltage sense wire. It is designed to be connected directly to the battery so that the alternator can supply a more accurate charging voltage, as it compensates for the voltage drop in the high current wire from the alternator to the battery. You can connect that terminal directly to the output terminal on the alternator and it will work just like your previous alternator. If you want to take advantage of the voltage sense, you will need to run a wire from the third terminal to a positive battery terminal. A 14-16 gauge wire should be sufficient.
    bravoo67 and CondoCruiser Thank this.
  7. CondoCruiser
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Yeah that will work. The further away from the battery for voltage drop the better is why many run to the ignition switch.
  8. CondoCruiser
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    I'm curious where he ran his ground wire.
  9. windsmith
    7,296
    6,031
    Sep 2, 2011
    NEPA
    I'd be wary of connecting the sense wire anywhere but the alternator output terminal or a positive battery terminal. The reason being that the voltage at the ignition terminal will fluctuate widely with changing current draw through the ignition circuit. That could cause the alternator to provide an incorrect voltage to the batteries. The batteries require a fairly narrow charging voltage range to be properly charged. While charging outside of that range will frequently work, the batteries' life could be shortened significantly due to chronic over / under charging.
  10. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    I agree with windsmith, not a good idea to run that wire to the ignition switch. The purpose of the wire is to compensate for voltage drops/changes in loads to make consistent voltage at the batteries, which is where you want it. Hooking up to any other place negates the purpose of it. Relocating it to increase charging voltage is a band-aid fix for another issue.
