New Cascadia w/ Detroit Powertrain will it be good for hauling 80K?
Discussion in 'Ask An Owner Operator' started by mishka0313, Jan 5, 2019.
  1. mishka0313
    mishka0313 Bobtail Member
    Hi everyone. I'm looking into buying new Freightliner Cascadia and they offer Cascadia with detroit powertrain. From the engine all the way to the end made by Detroit. It sounds good because for once you don't have need to worry who made what in a truck and everything made and tested in one place, utilizing everything possible into one piece. But Detroit Powertrain has only few specs. DD15 engine will have only 400 horses and differential ratios is going to be 2.28 or 2.16. And it is sounds like is going to save some money on fuel, but is 2.28 any good for hauling 80k? If anyone has experience with it, I would like to know. Thanks
  3. DUNE-T
    DUNE-T Road Train Member
    6,944
    16,849
    May 10, 2015
    Detroit, MI
    Get 500hp and 3.55 if you are planning to haul 80k regularly. If driving in hilly area might even want to go 3.90
    Blagoje, 77fib77 and Broke Down 69 Thank this.
  4. mishka0313
    I have right now 455hp with 2.64 direct drive and feel pretty happy about it. And cruising with 66-67 mph at little under 1400rpm. But it feels like the sweetest spot for the engine between 1200 to 1300 rpm.
  5. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    2.28plus 400 ponies plus 80k equals one slow uphill truck
  6. mishka0313
    I feel the same about it, but for some reason Detroit didn't make anything else.
  7. Midnight_tim
    Midnight_tim Light Load Member
    93
    123
    Dec 19, 2018
    If you stay flat you regularly you will probably get by but I'd look for a better rig if you can.
  8. BrandonCDLdriver
    BrandonCDLdriver Road Train Member
    1,191
    1,462
    Sep 1, 2017
    HP sells the truck, torque pulls it down the road.
    The newest DD15 engines can have almost 2000ftlbs of torque. Mine has 455hp (I think) and the newest engine with like 1950ft lbs of torque. At 80000 it does quite well as long as you're not trying to climb the side of a pyramid. I don't know any truck that was at gross that blew my doors off climbing the hills in NC. We were all slugs. Flat and level it does great. Small hills and such no problem at all. Even loooooong grades it only loses a few mph by the top. And my truck is governed, in one that isn't you could get a running start and do even better.
    haycarter and Omega1 Thank this.
  9. Omega1
    Omega1 Heavy Load Member
    721
    1,598
    Nov 18, 2017
    Oregon
    Spot on Brandon. I ran the same configuration on my last truck with similar results.
  10. danny23tx
    danny23tx Road Train Member
    1,494
    2,324
    Feb 16, 2016
    Austin,Tx
    My DD15 is at 455hp pulls well and decent fuel mileage. Former Prime truck setup for OTR , not sure the gearing.
  11. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,058
    Nov 18, 2014
    Land of local
    Hook, line, and sinker you took the bait from a bean counter that's never made it out of low range in the parking lot.
    Buying new, spec the truck properly for whatever your niche is. 505/1850 13 speed and 3.42-3.70 if running 295/75/22.5
    That's where I'd start.
    Edit: after looking at Detroit's specs is still listing the 15 as having 1750. Don't know why for Christ sakes the 13 L has 1850. I'd opt for dd13 505/1850. That motor is more than adequate for 80k and less. My take is you have less dpf/scr issues with a truck that hasn't had it balls chopped off. Lug lug lug, 400hp always struggling to get out of its own way and always down at max tq is not your million mile recipe.
    ajax1337 and AModelCat Thank this.
