New clutch caused change in rpm to road speed ratio
Discussion in 'Ask An Owner Operator' started by Jbcjohnb92, Jan 8, 2020.
  1. Jbcjohnb92
    Jbcjohnb92 Bobtail Member
    Just had new clutch installed in a 2013 Cascadia with a dd15. My rpm at highway speeds has dropped around 300 rpm. I now tach 1100 rpm at 70 mph. Prior to the new clutch it was tach around 1400 - 1500
    Any explanation?
  3. Mattmanstroked
    Mattmanstroked Light Load Member
    185
    279
    Nov 24, 2019
    Unless the old clutch was slipping badly I don't know how this could be
  4. Dale thompson
    5,175
    43,362
    Nov 20, 2013
    commerce twp,mi
    Impossible if the clutch was slipping that much the heat would cause catastrophic failure in less than 30 miles.
    Bean Jr. and Rideandrepair Thank this.
  5. 062
    062 Road Train Member
    6,216
    33,468
    Oct 20, 2013
    Sounds like they put a od trans in where a direct drive was.
  6. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Speed or tach sensor messing up. It is not possible for the clutch to change speed.
    GFTLLC, Bean Jr., Swine hauler and 2 others Thank this.
  7. HillbillyDeluxeTruck
    5,933
    30,328
    Mar 3, 2013
    San Antone
    Starmac is right. Id bet on it being the speed sensor in the rear of the trans. Check to makee sure its installed correctly.
    GFTLLC, Bean Jr. and Swine hauler Thank this.
  8. Twin Sticks
    Twin Sticks Bobtail Member
    30
    47
    Jul 23, 2019
    Clutch changing road speed not possible. Ditto on a sensor
