New Clutch installed has triggered start issues with depressing clutch pedal.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Rooster57, Dec 28, 2020.
  1. Rooster57
    Rooster57 Bobtail Member
    7
    Dec 9, 2020
    New Clutch installed 800 miles back.
    Ran three days and now clutch pedal has to be depressed through floorboard to start it seems !
    Any suggestions? 2013 Prostar
    Dealer install .
  3. AModelCat
    159,266
    Somebody must've dinked around with the clutch linkage when they replaced the clutch.
  4. Rooster57
    7
    Dec 9, 2020
    My thoughts as well.
    Just don’t won’t to get me stranded!
    Rideandrepair Thanks this.
  5. Antinomian
    Antinomian Road Train Member
    2,113
    3,336
    Feb 17, 2013
    I thought Prostars had hydraulic clutch linkages.
  6. AModelCat
    159,266
    OP must've added that because there was no truck info when I first posted lol.
  7. Rideandrepair
    17,343
    56,259
    Aug 8, 2015
    Sounds like it’s not adjusted right. Free play should be 1.5”- 2”. Clutch brake should engage about an inch off the floor. Maybe they turned the flywheel, or swapped it with a thinner one, and you need an oversized clutch brake. Adjust clutch, getting proper gap, making sure clutch brake engages. Check linkage for slop. It’s either going to work right, or need a thicker clutch brake, or has worn linkage parts.
  8. Rooster57
    7
    Dec 9, 2020
    Have a run towards the dealer today luckily and am going to have them recheck.
    Thanks for feedback!
  9. Carrierxpressllc
    Carrierxpressllc Bobtail Member
    i am having the same problem, any luck with yours??
