New Double drop with open center.
Discussion in 'Flatbed Trucking Forum' started by nikmirbre, Dec 14, 2017.
  1. nikmirbre
    nikmirbre Road Train Member
    5,377
    9,590
    Jul 27, 2011
    High Point NC
    Im looking to buying a 3 axle DD. Ive ran across one and I'm sorta haggling on the price but, my only concern is the center of it is open..... Would I run into issues of not being able to load at different places because of this? Ive looked for someone out on the road who has one but Ive yet to see one the past 2 weeks.....
    Edit to add: some people say Double drop others say RGN.... I mean RGN...
  3. beastr123
    beastr123 Road Train Member
    2,808
    22,892
    Jan 2, 2014
    Moose Jaw SK CAN
    If the trailer is rigged for outriggers then chances are the "open area" is where you store your outrigger decking boards when not in use. ask about the boards from the dealer, he may have options such as oak or aluminum
    nikmirbre Thanks this.
  4. Rontonio
    Rontonio Road Train Member
    6,251
    45,421
    Aug 9, 2009
    Yes you will run into a very small number of places that may not load you. However, the vast majority won’t care. The open center will save you some weight and make other things easier to tie down. A lot of times you can put a bottom tarp down if is a tarp load.
    You can always add the decking in the future if you feel you are losing a significant number of loads.
    I would much more concerned will well length, deck height and concentrated weight rating
    Oxbow and nikmirbre Thank this.
  5. nikmirbre
    5,377
    9,590
    Jul 27, 2011
    High Point NC
    Yea ill have 29 in the well(It may be 29'6). deck height is 18 inches.....
  6. nikmirbre
    5,377
    9,590
    Jul 27, 2011
    High Point NC
  7. nikmirbre
    5,377
    9,590
    Jul 27, 2011
    High Point NC
    Its mechanical detach. I absolutely can't find a nice used one with a hydraulic neck.....
  8. Rontonio
    6,251
    45,421
    Aug 9, 2009
    Mechanical or Hydro?
    If mechanical, invest in having a really good set of ramps on your truck - not the stupid short and steep one side you will see.
    I had a 35 Ton mechanical - had lots of fun with it. Be careful, the rates have been beat up on those pretty good .
    Oxbow Thanks this.
  9. nikmirbre
    5,377
    9,590
    Jul 27, 2011
    High Point NC
    can you give a link to some ramps? I assume you mean the ramps on the front?
  10. Rontonio
    6,251
    45,421
    Aug 9, 2009
    No
    The ramps on the back of the frame of your truck - the rollers on the front of the neck ride up the ramps to lift the trailer so the kingpin will hook to the fifth wheel.
    Oxbow and OLDSKOOLERnWV Thank this.
  11. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    image.jpg image.jpg image.jpg Few examples . Dad's truck when I was coming up , had a ramp set up close to the middle pic. He could pick up a loaded van dropped with the landing gear up.
    nikmirbre and OLDSKOOLERnWV Thank this.
