New fridge with flammable refrigerant?
Discussion in 'Questions From New Drivers' started by SuperRookie, Sep 1, 2019.
  1. SuperRookie
    SuperRookie Light Load Member
    51
    64
    Apr 11, 2012
    Eton, GA
    Any of yall using any of these new mini fridges? I was cool till I read that it has flammable refrigerant in them. Only thing I really worry about is how well these mini fridges are holding up to vibrations? I plan on strapping it to my top bunk with a load strap so it cant love around. Any thoughts?
  3. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    Did you already buy one? Curious what the prices are since r1234yf costs ten times as much as r134a.
    I've been using mini fridges for years and never had one leak. The thermal limit switch is usually what goes bad in them when the compressor starts to draw too many amps.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,300
    Apr 9, 2009
    Humboldt, Sk
    Factory truck fridge only worked 14 months, $1400 for new one.
    Walmart small student fridge on a large inverter, working over two years now. I used ratchet straps to tie it down. Only $130, even if it quit now, I could by a new one every two years for twenty years to equal the cost of the Freightliner fridge.
  5. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Yes, now they use butane as refrigerant in small fridges. Thanks tree hugers.
    Gumboslef9384, FlaSwampRat and rachi Thank this.
  6. SuperRookie
    51
    64
    Apr 11, 2012
    Eton, GA
    Yeah I bought a nice little 3cu ft one for 130. But I was worried about the vibrations since these roads are so rough in a truck. Lol.
  7. Espressolane
    19,222
    121,559
    All refrigerants are flammable. Some are quite toxic when they do burn.
    Lepton1 Thanks this.
  8. SuperRookie
    51
    64
    Apr 11, 2012
    Eton, GA
    So once I have it secured on top bunk I should be ok right?
  9. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,525
    May 28, 2015
    How does that pull on your batteries at night?
    I'm in the same situation.
    Factory unit bit the dust.. not paying $700 for a new one.
    No APU.. so, how much draw to keep it going at night when I'm not idling?
    I try not to if it's not hot.
    That's been what's holding me back.
    Don't wanna wake up to click click click.
    rachi Thanks this.
  10. Lepton1
    Lepton1 Road Train Member
    12,647
    25,593
    Nov 23, 2012
    Yukon, OK
    I wouldn't recommend the top bunk. If at all possible put it on the floor somewhere. The top bunk has a LOT more violent motion as you go over potholes. The top bunk will start destroying your refrigerator and the contents.
  11. snowwy
    snowwy Road Train Member
    20,628
    13,350
    Jul 6, 2009
    I think it was Chrysler that posted a video of their experiment with the 2 freons.
    IIRC. They were looking in to producing their own NON flammable. They didn't want to use the new 1234. Felt it unsafe in an accident. Don't know where they're at on that idea these days.
    All freons are flammable but 134 really isn't compared to 1234.
    The start date was January 1, 2017. Some manufactures started as early as 15 models. Chrysler dodge trucks started in 15 but the Chrysler Jeeps still had 134 for the 16 models.
    Yes, google has different dates. But that's the date published in the manual that is needed to be read to pass certification if anyone wants to buy quantities greater then 2 lbs. You can buy all the cans you want. You just can't buy 1 can over 2 lbs.
    Currently, 1234 is only sold in 10 lb containers to the tune of $700.
    My last 134 container was 30 lbs. for $170. Last year.
    lilillill and Lepton1 Thank this.
