New Graduate Wondering About These Companies
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by TruckinBro, May 2, 2011.
  1. TruckinBro
    TruckinBro Bobtail Member
    35
    9
    Apr 17, 2011
    Sylvania, OH
    Is there any bad news on these trucking companies?
    These are my choices to drive for.
    U.S Express - out of Chattanooga, TN
    Roehl - out of Marshfield, WI
    Werner Enterprises - out of Omaha, NB
    Garner - out of Findlay, OH
    MCS - out of Northwood, OH
    Star Transport - out of Morton, IL
    Swift - out of Phoenix, AZ
  3. Dryver
    Dryver Road Train Member
    2,818
    2,575
    Nov 30, 2008
    Sioux Falls, SD
    IMHO, Roehl is the only one I would consider, I don't know Garner or MCS.
    U.S Express - out of Chattanooga, TN NO
    Roehl - out of Marshfield, WI YES
    Werner Enterprises - out of Omaha, NB HELL NO
    Garner - out of Findlay, OH ?
    MCS - out of Northwood, OH ?
    Star Transport - out of Morton, IL NO
    Swift - out of Phoenix, AZ[/QUOTE] NO
  4. blanks
    blanks Light Load Member
    134
    16
    Apr 12, 2011
    Chatham, ON
    I've heard some drivers say good things about this company, definitely avoid Werner Ent. if the experiences of other drivers on this forum mean anything.
  5. postmandav
    postmandav Medium Load Member
    313
    90
    May 18, 2008
    south portland, maine
    There are many threads on this site having to do with most of the companies you listed. Use the search feature and you should find some answers.
    As to Werner, I worked for them for 1 year and 9 months and thought they were ok. If you ever were dispatched to Laredo, be prepared to sit for at least 3-4 days. They do not have a lot of freight leaving Laredo. Also, be prepared to run as a team. The first week you will only be able to drive between the hours of 6am and midnight. Hopefully your trainer will give you good info regarding qualcom, shifting, logbooks(you will be required to to a paper log during your time on the truck, you will also do the elog as well, but they want to make sure that you are able to do the paper logs correctly).
  6. aladdin sane
    aladdin sane Medium Load Member
    519
    290
    Dec 8, 2007
    Towanda, Kansas
    The best thing you could do is stay away from the TL industry altogether.
  7. sedain
    sedain Medium Load Member
    419
    328
    Dec 4, 2010
    hmm,ya,that about sums it up...the truckload otr thing...lets put it this way.
    if you can be keep a positive mindset while working 28 days a month without being home in that time frame, making on average minimum wage while under drachonian rules as far as idle percentage and under strict rules per the dot and company...
    this is your dream job, you can do it!
    in all reality there isnt too much of a difference in the companies listed,they use the same business model.
    i would use other info like for instance the one w/ the best safestat score, but i bet there isnt much difference between most of those...but that may help you make your choice.
    another criteria i would check on is who is based closest to where you live...and if they have dedicated accounts in your area?
  8. bk1
    bk1 Bobtail Member
    5
    I would find a company that is a lot smaller than the ones you have listed. On a side note I worked for Roehl, and would say if you run out of the Gary, Indiana terminal, you will regret every minute of it!
  9. ETCH5858
    ETCH5858 Medium Load Member
    605
    371
    Feb 25, 2009
    Attitude is everything in this field. Of the companies listed Roehl is probably your best bet.
  10. Big Duker
    Big Duker "Don Cheto"
    2,921
    2,867
    Sep 18, 2007
    Weatherford, TX
    Werner is lower than whale poop. Roehl used to be good company. Probably still best of those listed. Swift gets made fun of a lot, but you can get lots of experience there and they have the freight. Good luck. Get ready to eat a lot of s#@t sandwiches whereever you decide to go. Comes with the turf.
  11. Colonel B
    Colonel B Bobtail Member
    12
    4
    Aug 1, 2010
    NW Indiana
    We can no longer use the term "lower then whale poop" now we will use "Lower then Bin Laden"
    postmandav and xllxmrjohnxllx Thank this.
