New guy, First truck. Need some engine advice! 3406E power.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by double brew, Mar 7, 2015.
  1. double brew
    double brew Light Load Member
    76
    20
    Mar 7, 2015
    Should I start asking these questions in a tech section?
  3. ROBSREDFORD
    ROBSREDFORD Light Load Member
    266
    139
    Sep 2, 2008
    MIDLAND, NC
    The true 435 s don't have the same injector , turbo and camshafts as the 550....cat will upgrade to 455 iirc....I have turned several to a factory 550 brake saver file low IC code file with great results....I would recommend checking complete pressure side for leaks and I'd run 1r0749 on the engine, fs1023 or 2568753 on the frame for fuel filters ....bump fuel pressure a tad and run the 78mm s400 and hold on...
    2CAN Thanks this.
  4. double brew
    76
    20
    Mar 7, 2015
    I'm assuming the local cat shop wouldn't turn things up like this.? Lol. The turbo in there now has an internal wastegate. Would the borg Warner need to be gated as well?
    Fuel pressure is is something just short of 90lbs at idle, no leaks on the boost side, no shaft play on the turbo, and I laughed how small the compressor wheel was compared to the one on my 50 chevy. Lol. and I just got the book so I can run the overhead. Maybe this weekend. Trans temp, rear end temps, and boost gauge are ordered. The air to air looks brand new, so that's a plus.
  5. Diesel Dave
    8,687
    24,721
    Jan 20, 2010
    Hesperia, Ca.
    My engine was born with a 435 (5EK series). Since then, I put a 550 BrakeSaver file (1LW series). Besides that, the only hardparts I have replace is the turbo, B/W stage 1 Non-gated and Vibratech harmonic balancer for insurance. My 5EK came with 58's injector's, the 1LW file calls for 57's, which equals, more HP. No problems anywhere, not even EGT's. My mpg vary's, seen 6.5 -7.3 base on fill up's.
  6. double brew
    76
    20
    Mar 7, 2015
    What injectors do the factory 1lw's come with? How much for a set of those? A grand?
    Who's b/w turbo did you go with? Pdi said they have special designed housings to work properly? I don't see a 1900 dollar difference for a little different design.? Do you think something like the Regular $600 s475 75mm/96mm 1.32 ar t6 housing work just fine? Or still a little small on the compressor side?
  7. maggard359
    maggard359 Medium Load Member
    476
    413
    Nov 20, 2013
    Florida
    It probably came with 10r0956. You can load a different file but I wouldn't without upgrading injectors. I have seen the 435 1LW with 139-0538 cam, I know that one was standard for 1LW, 2WS, and 6NZ for a long time. 1/2 watt 150ohm resistor on fuel temp is a great help and cheap. Turbo honestly right now I like the borg 177148 you can go to buyautoparts and have it shipped for about 1150 with a promo code which is the cheapest I have found and no core charge. Super 10 I don't believe is rated to handle the torque of the 550 file, I have never had one myself, but I may be wrong.
  8. tsavory
    tsavory Road Train Member
    1,910
    1,860
    Jun 4, 2013
    Paoli, IN
    not rated to handle but can be ran just have to be easy on it. 475 5ek puts out 1875 fp at 2100 RPM so a 16610b is rated a 1600fp right now i am running a 15610b in a 5ek running a 550 file got to be easy on her saving to put in a 18913b or a 18918b prefer the latter but finding and having the cash at the same time can be a pain.
  9. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    if you put an auto in manual you will get even worse fuel mileage
    i never put mine in manual ever
    pull WY and Donner every week
  10. double brew
    76
    20
    Mar 7, 2015
    I WILL be switching the auto 9/10 to manual. There's nothing more annoying than not having control of gear selection in a manual transmission. That, and having to rev it to 1700+ to get it to shift into high gear.
    I dont plan plan to do any engine work until it has a few oil changes on it, or I need to replace something, I'm just trying to line up as much info that I can.
  11. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    What engine code is it? I thought a 99 would be a 2ws? Around here the 435/455's were usually made around 96 or so. They were reliable but not known as powerhouses. They also had a 500 around then too but you had to change hard parts to make a 435/455 into a 500.
