New injectors what cup to use???
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Binderdavemays1, Oct 7, 2024.
  1. Binderdavemays1
    Binderdavemays1 Light Load Member
    169
    80
    Jul 30, 2024
    Luebbering Mo
    So installed new injectors in the 1984 international eagle big cam 350 turned up 400. The injectors were supplied by the last owner, but the truck did not run correct acted like it was dumping water down through the cups and was putting too much diesel to the motor.
    I eventually had the truck towed to my house cause I didn’t like the way it ran. I want to pull the injectors back out, pull their heads and replace the cups. What material do I use and what cup do I use please? They make cups in different materials just want to use the correct ones.
    Reason for edit: Additional information
  3. Inderjit
    Inderjit Heavy Load Member
    750
    726
    Sep 17, 2017
    The injector cups are made of copper. There are special tools required to install roll and cut the seat to the correct protrusion. Pull the injectors and pressurise the cooling system and see if any of the cups are leaking.
    Binderdavemays1 Thanks this.
  4. Binderdavemays1
    169
    80
    Jul 30, 2024
    Luebbering Mo
    Pressurize the cooling system
    With air im assuming
    The old injectors were junk and there was water in the oil
  5. Inderjit
    750
    726
    Sep 17, 2017
    Yes about around 10 psi should be adequate.
    Do you have a rad/cooling system pressure tester?
    How much water was in the oil and was it water or antifreeze?
  6. Binderdavemays1
    169
    80
    Jul 30, 2024
    Luebbering Mo
    Antifreeze it appeared
    No rad tester yet
    A lot of water
  7. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    injector tubes are junk think you have to pull the heads for that
  8. Inderjit
    750
    726
    Sep 17, 2017
    Yes you have to pull the heads.
  9. Binderdavemays1
    169
    80
    Jul 30, 2024
    Luebbering Mo
    Oh, not worried about pulling the heads soda. Speak, more worried about calling the cops and replacing with new ones sounds like it’s a bit of a process.
  10. Binderdavemays1
    169
    80
    Jul 30, 2024
    Luebbering Mo
    I don’t like voice text
  11. Binderdavemays1
    169
    80
    Jul 30, 2024
    Luebbering Mo
    That should say I’m not really worried about pulling the heads as much as I am pulling the old cups and replacing with new ones it sounds like it’s a bit of a process
