I have a 1993 Freightliner 3 axle truck. I just put a new leveling valve on but don't know
what the cutoff height should be.
Any ideas?
Thanks
New leveling valve. Height adjustment? 1993 Freightliner 3 axle
Discussion in 'Freightliner Forum' started by Rick Wilmath, Mar 4, 2018.
Rick, on a Peterbilt anyways, the arm of the leveling valve should be level with the lower edge of the frame rail. They also have a guide for the distance in inches that the bag height should be from the bottom of the bag support platform to the bottom edge of the frame rail as well. Different bags for their different suspensions. Hope this helps a little!
Rick Wilmath Thanks this. -
Need to know what suspension you have. Typically its a measurement between something like bottom of frame or axle stop to the top or centre of the axle housing.
I got a print off from my local KW service department when I bought a replacement level valve many years ago. It's in the glove box. Everyone seems to measure in different ways on different suspension types. Mine is an AG380. What kind of suspension do you have? Maybe someone here knows. Really though you'd be better off checking with a dealer if you want to be sure the specs are right.
Google.com Google knows everything
Don't know if freightliner had their own suspension back then, but here is Freightliner Airliner suspension height settings.
http://www.wsnorth.com/wp-content/uploads/2015/02/RIDE_HEIGHT_ADJUSTMENT.pdfJed2009 and Rick Wilmath Thank this. -
Rick Wilmath and blairandgretchen Thank this.
Thanks everybody for the help!
