hi i need a good advice here if anyone knos whats my best choice to try to get dispatch since im new authority hopefully some of u can help ive been trying to set up with a few brokers but shows on the set up that i need to have some time active to be able to book a load or get set up
New MC and DOT authorities, who will work with me?
Discussion in 'Ask An Owner Operator' started by whitekw, Apr 5, 2019.
Sounds like something you should have had figured out well before going on your own. Someone will probably be by to help soon.
Use the search bar in upper right corner. Chr,tql and several others use new authorities.
C. H . Robinson, TQL, Landstar, J. B. Hunt, new authority, no problem. Expect a decent rate? Problem!
062 Thanks this. -
Uber Freight, Convoy are a couple more, JB Hunt requires 90 days.
I do not like CHR but they will dispatch you for free. They will make you a living, give you quick pay and definitely keep you moving. You will haul heavy freight on the cheap but if you roll with it for a few months you'll learn a lot and be able to experiment on your own more. Once you hit 6 mos. authority you won't have much trouble with brokers.
