New Pete 5mph govna
Discussion in 'Peterbilt Forum' started by Gclancaster, May 11, 2011.
  1. Gclancaster
    Gclancaster Bobtail Member
    Does anyone know why my brand new Pete would reed no warnings on the dash but at the same time it shows eng stop and I scrolled thru the engine stats and it reads now that it's governed at 5mph. It was a little low on oil is all I could find when I checked all fluids including DEF. I'm hoping it's just in some kind of computer shut down any help would be great- thanks G.
  3. popmartian
    popmartian Road Train Member
    1,015
    489
    May 31, 2009
    looks like a shutdown engine protect mode. The ECM has codes you can access via the dash, check your manual to find which switch activates the fault codes. Warning if your engine has any major faults, it will not run.... that is so the driver avoids a major engine repair. you should call the national hotline for Pete Service related issues or your company breakdown call center.
    No Hope No Change! Just the same old crap warmed over !
