New Schneider trucks getting epus/apus?
Discussion in 'Schneider' started by deandean, Jul 18, 2013.
  1. deandean
    deandean Bobtail Member
    24
    13
    Jul 7, 2013
    Are newer Schneider trucks getting the epu/apu for cooling in the summer? I heard that all the new trucks Schneider is going to be getting are going to be equipped with an epu/apu is it true? I hope so I don't see how in the world you could sit there in 90 degree weather - and of course even hotter in the truck - and try to rest. It's inhumane to put a dog in a hot vehicle and leave him there, you can even go to jail for it - but it's ok to put a truck driver in a hot truck and expect him to be able to rest? Doesn't seem right at all.
  3. 123456
    123456 Road Train Member
    10,555
    5,746
    Oct 22, 2010
    32179
    I honestly doubt it.
    And even if they did,
    it would take quite a few years to replace all their trucks.
  4. abn75
    abn75 Light Load Member
    155
    92
    Jun 18, 2013
    What I was told in orientation was that the new trucks should be coming with that electric cooling system.
    But even with out it I stay cool. I idle the truck.
    Sent from my SCH-I605 using Tapatalk 4 Beta
  5. deandean
    24
    13
    Jul 7, 2013
    Well I guess I will cross Schneider off my list. I've read the sensors sometimes won't kick on even when its 90 degrees out and who knows how hot it is in your truck then. Sounds pretty brutal to work for Schneider.
  6. Jorihe84
    Jorihe84 Road Train Member
    2,763
    1,333
    Sep 1, 2010
    North Florida
    Schneiders is set at 90????? Ours at Arnold are at 70. Ive got mine to work at 68. Were allowed to idle as much as we want as long as we meet the sensor setting.
  7. abn75
    155
    92
    Jun 18, 2013
    I've yet to have the truck not idle when I wanted it to. Supposedly it's something like 20-70, but even on the nights when it was below 70 mine ran all night long.
  8. stevep1977
    stevep1977 Road Train Member
    3,701
    22,351
    Dec 23, 2010
    Chicago, IL
    The only way the truck won't idle is if the sensor isn't programmed correctly. Maintenance will fix it. Idle range is under 20 and over 70. But with heat coming off of the truck/exhaust, it tends to idle above 65 or so, but on the other end it won't idle in the winter until the temperature approaches 10-15 degrees.
    The only slippery slope is what to do in no idle states. Ultimately, I just break the law because I'm not boiling in the truck. If I do ever get ticketed for idling I'll be sending the bill Schneider's way.
    deandean Thanks this.
  9. ricecakeftw
    ricecakeftw Light Load Member
    248
    60
    Oct 2, 2012
    They aren't actual APU's. They are called a "Part Smart System" which is a A/C system that runs solely on battery. It can run between 10-12 hours. Some of the trucks are fitted with them. I believe the temp sensor is set at 90 for idling and 20 for winter. BUT: the trucks that aren't equipped with it are at 80-20. I have had no issues with idling and being comfortable.
  10. jakecat22
    jakecat22 Road Train Member
    1,529
    26,294
    Jul 1, 2011
    My old truck(when I was OTR) had the Park Smart system on it. IMO, if SNI isn't going to get APU's, this system is a nice alternative to idling. It will last all night and keep the bunk nice and cool. The ONLY problem is, if it breaks, our mechanics are clueless on how to fix it so it has to go to a dealership. The dealership mechanics are also clueless on how to fix it and have to call in someone else LOL.
  11. gentleroger
    gentleroger Road Train Member
    7,414
    20,111
    Jun 1, 2010
    We're going to the Parksmart system for the vast majority of the trucks in the shoithern divisions. For those of us north of the Mason-Dixon we just idle when it's over 70 degrees while keeping your total idle time for the year under 10%.
    Staying warm/cool isn't the issue. Having electrical power can be problematic but there are work arounds that aren't overly onerous.
