New T-880 MX-13 Allison
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Rolling18, Aug 26, 2018.
  1. Rolling18
    Rolling18 Light Load Member
    170
    34
    Dec 11, 2008
    Portland, OR
    I'm about to be the owner of a 2018 KW t880 MX-13 / 455 hp W/ Allison (dump... lots of Idling!)
    I'm expecting to have many Emissions related problems/ C.E.L's
    I am thinking about getting one of those Laptops on E-ghey W/ Davie, Allison, and bendix diagnosis and programming software.. as well as tons of others...
    any thoughts on the Allison "fuel sense 2.0"???
    this is my first emissions truck as an O/O any advice on these things???? tips? (other than "run from Paccar!") heh .. Did I forget to mention anything specific?? ect ect. Thanks!!!
  3. Goodysnap
    Goodysnap Road Train Member
    3,716
    9,022
    Jul 12, 2017
    You will love the MX/ Allison combo. Stay ahead on your EGR/sensor and DPF cleaning intervals and you'll be fine. Take the time to look the chassis over, especially after treatment wiring and make sure it's all shielded from rubs that may cause a derate.
    Justrucking2, Oxbow and Rolling18 Thank this.
  4. FdEF
    FdEF Light Load Member
    70
    57
    Dec 5, 2017
    Ogden, Ut
    Be sure not to idle it at 850 or 880. With a paccar you really should always Idle at 1000-1100 rpm
    Oldironfan Thanks this.
  5. spsauerland
    spsauerland Road Train Member
    4,296
    10,887
    May 31, 2010
    West Harrison, In
    Best not to idle @ all! Latest advice from Paccar on idling is use the lowest RPM possible that maintains coolant temp above 150F. Best advice is what @Goodysnap said. READ your owners manual and follow the maintenance intervals. Personally, I would stick with Paccar filters and a reputable oil. We still run 15w40 in our MX's because of a mixed fleet. Buy good fuel, keep water separator drained and buy quality DEF. As far as dumptruck goes, keep everything greased and often!
    Oxbow and Goodysnap Thank this.
  6. Rolling18
    170
    34
    Dec 11, 2008
    Portland, OR
    THIS: I have read allot of problems come from wiring... and with the dump truck lots of off roading and bouncing, washboards, its like a constant test track! you see the frame flexing allot.
    i will take EXTRA care for watching this.
    I literally am gambling my house on this new venture!
  7. Rolling18
    170
    34
    Dec 11, 2008
    Portland, OR
    Hmmm witch advice.. Best not Idle at all or idle at 1000 to 1100 rpm.. o_Oo_O opposite advice.. hmm idling is unavoidable in my circumstances, thats why Im looking at preventaive measures.. mayby an extended aftertreatment warranty.
  8. spsauerland
    4,296
    10,887
    May 31, 2010
    West Harrison, In
    We get the 5 year/500,000 on engine and aftertreatment on our Paccar engines. Aftertreatment harnesses are NOT included with this coverage! This is covered under the bumper to bumper warranty. Paccar financial was giving a smoking deal on the 3 year/300,000 warranty if you financed through them. We have a 2015 T880 quad axle with Ultrashift Plus. Haven't had many issues except a cracked EGR cooler. We change oil every 12000 mile and grease every 3000. Set overhead @ 50,000 and will do again @ 200,000 when we clean the DOC/DPF. Air management sensor/tube service every 100,000. Taking delivery of two Pete 567 quads with MX/Allison combo later this month. I will review the EPA2017 MX maintenance recommendations and adjust to past fleet experience.
    Oxbow, magoo68 and Goodysnap Thank this.
  9. Rolling18
    170
    34
    Dec 11, 2008
    Portland, OR
    Good info there!!
    the warranty offer now is only 3/300k if you spec a Paccar motor, or $3000k rebate.
    I chose the rebate. I am going to try for the warranty as well.
    I wonder if there is an option to buy the warranty near the original ending period?
    i plan on a 12k oil change interval as well... cheapest insurance.
    do you do your own aftertreatment maint. or???
    tell us how you like the allison / MX combo later:)
    Oxbow Thanks this.
  10. spsauerland
    4,296
    10,887
    May 31, 2010
    West Harrison, In
    Do our own maintenance engine/aftertreatment including some warranty. Warranty is always much cheaper @ time of original sale. They will sell additional warranty @ a later date. Warranty is a slippery slope and you need to have a good working relationship with the service department and a good warranty person in charge at dealership to make it work out for you.
    Oxbow, Goodysnap and Rolling18 Thank this.
  11. Rolling18
    170
    34
    Dec 11, 2008
    Portland, OR
    o ok ill deninantly see what I can do!
    Oxbow Thanks this.
