New to big trucks with my 1968 peterbilt 359
Discussion in 'Peterbilt Forum' started by crsracing, Aug 15, 2025.
  1. crsracing
    crsracing Bobtail Member
    18
    27
    Aug 15, 2025
    Hello, I picked up a 1968 peterbilt 359 dump truck awhile back. It started life as a log truck I was told. Has a small cam Cummins, was a 5+4 but unfortunately some one put a standard 10 speed in place of the 5. It's a bit rough around the edges but does the job, which is hauling in gravel and general farm use. The is my first big truck prior experience was just a 26ft freightliner fl60 and a couple fire trucks. I picked the Pete as I have always wanted one and figured I might as well get something I actually had an interest in/ wanted to fix up instead of something just to get the job done. First order of business is I have a leaking axle seal on the driver's forward rear axle and the shifter for my aux box stopped working on my 160 mile trip home. Well on to the picture, again a little rough but it should look better in a few years.
  3. d o g
    d o g Trucker Forum STAFF Staff Member
    24,953
    55,121
    Sep 20, 2010
    Texas
    Welcome to TruckersReport. That's a pretty sweet old Pete. The guys here will be able to help you with that project, so don't hesitate to ask anything.
  4. 201
    201 Road Train Member
    13,014
    26,865
    Apr 16, 2014
    high plains colorado
    dog beat me to it, I thought I was the unofficial welcome,,,guy, but welcome aboard. You'll find we're all bozos on this bus. Nice truck, and not just any 359, a "small window" to boot. '73 was the last year and quite rare. One thing, someone put a 10 speed in place of the 5? So it still has the aux. 4 speed box? Who do you think you are, Snowman? Just kidding, you didn't say what rear suspension, being a log truck, I would guess spring, or worse, if just doing local stuff, I wouldn't bother changing it. Leaking axle seals could indicate metal contamination, and depends how bad. Easy fix, and change the oil, it may look like metallic paint. Small cam Cummins, what 290, 335, 350? Good motors and flat dash? I had a '72 small window, was a heck of a ride. More pictures, and glad to meet you.Love the Pete :thumbup:
    Sorry for the poor picture, try this, my '85 daycab
  5. crsracing
    18
    27
    Aug 15, 2025
    Thanks! I realized pretty quick this one had quite a few differences and that you didn't see them as much. I was curious when they switched to the newer style cab so thank you for that. The rear suspension is a Hendrickson walking beam. I still need to Id the rear axles and what small cam it is. It does indeed have a flat dash. Unfortunately even with all those gears I have a top speed of 62mph on the governor, so although it's low priority I want to switch that 10 speed out for something better matched. Your 85 looks nice!
  6. 201
    13,014
    26,865
    Apr 16, 2014
    The smaller windshields 359 ended in 1972, but the taller windshield 359s came out later in '73, so some early '73s were actually leftover '72s. Taller cab, better doors, still same crappy electrics, but walking beam, aka "rubber pad" , no springs? None tougher, but rough ride and top speed of 62, sounds like some short gears there, probably 4:88 and only 2 kinds of axles used, Rockwell or Eaton, and should be a tag near the air compressor on what motor you have, usually gone missing, 350 SC was a common motor then. Steer axle brakes? Many older trucks didn't have front brakes, and I see it has a butterfly hood, I think tilt hoods came out around then, but yours has a bigger grill than the older "needle nose" Petes. You'll find, you'll get a lot of respect with that old gal around the stone pile.:thumbup:
    jaffles, Geronimo17, Sons Hero and 3 others Thank this.
  7. crsracing
    18
    27
    Aug 15, 2025
    I had a couple surprises when I first looked it over, one was rubber pads and no springs the other was no front brakes lol! I'm sure I can look it up but what's the best way to identify Rockwell vs Eaton? Unfortunately the tag on the Trans is missing so im not sure what ratios are in it. I knew the tag for the motor was over there but just kept forgetting to look, maybe I'll snag a picture of it latter today. It is a tlit nose, and I definitely like the look of the early cab and square doors better.
    201 and MACK E-6 Thank this.
  8. MACK E-6
    50,637
    244,884
    That’s a fine looking truck for its age and what it does. :yes2557:
    Bean Jr. and Deere hunter Thank this.
  9. 062
    062 Road Train Member
    6,422
    34,359
    Oct 20, 2013
  10. Oxbow
    Oxbow Road Train Member
    13,985
    146,150
    Nov 24, 2015
    You most likely have nothing wrong with the aux trans "shifter". If you round the corner when shifting you can stick the pin in between the shift mechanism. I'm not able to describe the situation well, but if you look at the front/top of the aux trans you should see the shift linkage going to two rods going in to the trans. In neutral these should be even with each other. I bet they are not now. Take a bar or large screwdriver and pry lightly on one or the other and see if they will pop into place where they are even.
    We all used to carry a tool just for this purpose as anyone who has spent much time driving with an auxiliary trans (Brownie) has stuck the shifter by rounding the corners of the shift pattern.
    Some of the others can probably describe what happens better than I did.
    Enjoy the ride!
  11. SmallPackage
    5,964
    19,251
    Dec 20, 2019
    Marion Texas
    ‘68 the big power was the 335 with the small after cooler as an option. The size of a case of beer bottles. 10 speed in front of the 4 makes endlessly fun. We have a ‘71 359 with a 9x4 and a ‘67 351 with a 13x4. The brownie box linkage will get stuck and hang up all the time if you don’t shift the gears straight and “square” thru the pattern. Don’t “round” the corners so to speak. Carry a pry bar with you to pop the linkage back into neutral at the transmission tower when that happens and roll on. ‘54-‘72 was the unilite cab series with 2 basic generations so to speak. ‘54-61 were first gen with small Ford F-100 style instrument panel. 1962 was second gen and got a slight cab revision. ‘62-,72 was that cab, roof cap and rain gutter, doors, and dash changed. Built in 100% aluminum and 100% steel. Both with marine waterproof plywood floors. ‘67 was first year for the 359. The serial # (salesOrder#) on my ‘67 351 was built 7 behind the first 359.
    jaffles, Sons Hero, Bean Jr. and 6 others Thank this.
