New to me 1999 Mack CH613
Discussion in 'Mack Forum' started by phil p, Jan 28, 2021.
  1. phil p
    phil p Bobtail Member
    Hello All
    I have a 1999 Mack CH613 that the head lights will not turn off when the truck is shut down.
    The normal things that cause this have been checked, the headlights are the proper part number and the parking brake is on.
    The truck came to me with wiring diagrams but without a diagram of the fuse / relay panel.
    I would surly like this drawing to identify the fuses a relays.
    Thanks
    Phil P
  3. 062
    062 Road Train Member
    6,220
    33,474
    Oct 20, 2013
    My guess is the headlights are on a circuit that’s only live with the ignition on.
    @Brettj3876 any ideas
    JoeyJunk Thanks this.
  4. phil p
    They stay on all the time we have to disconnect the battery to turn them off.
  5. 062
    6,220
    33,474
    Oct 20, 2013
    That’s what I get for thinking. Hopefully that fella I tagged before will be along shortly.
    I would pull one relay at a time until they go out. It could be the relay welded itself shut. I had that happen on a 02 Mack and it nearly caught the truck on fire.
  6. glensts
    glensts Bobtail Member
    Nov 25, 2007
    Aylsham, Saskatchewan
    Is it only headlights or are you getting tail lights and 2 roof lights? Reason I ask is we had a harness connection that goes through drivers door by your feet corrode and melt. Causing lights to stay on. And get hot. this was on a 1997
    062 Thanks this.
