I bought a 2020 Cascadia 126 today with a DD15/DT12 combination. Drove it home 6 hours and everything went fine with the exception of the coolant level sensor being bad so I had to unplug it. Coolant tank is full but sensor says its empty. I'll take to the the local dealership later this week but before I do I have a few questions.
- It is currently set at 450 hp. No idea what torque setting is. Can all DD15 engines be turned to the 505 or 515 setting?
- The transmission shifts smooth and says "Economy" under the gear number. Is there a "Performance" option they can change it to?
- It has an idle shut down timer on it that wants to shut it down after about a minute of idling. This is unacceptable for me as it will be a pulling a hopper bottom and sitting under augers for 5-8 minutes at a time. Will they be able to disable this or lengthen it to 10-15 minutes?
- It is currently governed at 70 mph. Plenty fast for 95% of what we will do but it needs to go away.
New to me Cascadia 126 questions
Discussion in 'Freightliner Forum' started by golfnut34, Dec 15, 2025 at 6:56 PM.
