New to side loaders; advice?
Discussion in 'Questions From New Drivers' started by 338-Dark-Knights, Feb 26, 2012.
  1. 338-Dark-Knights
    338-Dark-Knights Light Load Member
    154
    20
    Jan 27, 2011
    Canton, GA
    I've been hauling OTR for several months now, almost never touching the freight to ld/unld. Standard sleeper and cab (T2000) with a 53' dry van.
    I am about to start driving a different trailer now and would like to know what I should expect as far as changes in operation, driving, pre-trip, and things similar. Not sure yet if I will have a single or dully tractor, but I'm sure it's going to be a day cab.
    I would guess the turning will be a concern as it may be a bit easier/faster to jack knife, and checking the tires on a trailer that has side walls which cover the majority of the tire (again, not sure what equipment I will operate) would be the more obvious first questions I' m going to have.
    Would the location have determining factors for the tractor? I'm going to be in a port city, probably some side streets that might be a bit narrow. Hilly, and I'm good with a clutch.
    Beverage truck, might have to watch for turn speed still, yes? Outside temp? I would think the truck moving would keep things from freezing; are there temp controlled trailers?
    I don't know much about the job, yet. I'm sure some questions will resolve as I go foward, and others will need more info once I start. For now, I will have to see where this thread takes me.
  3. Gizmo_Man
    Gizmo_Man Road Train Member
    1,226
    599
    Aug 15, 2011
    Hardly around
    Just drive it like you stole it..[​IMG]
    seriously, do what YOU ARE SUPPOSED TO DO, regarding pre and post trip inspections.
    Always remember to keep the doors closed when driving, lest you lose your load.
    I mean, I can't see too much difference. If you are a truck driver, then drive!!:biggrin_25522:
  4. Allow Me.
    10,679
    12,240
    May 28, 2009
    Rancho Mirage, Ca.
    Yeah, single screw day cab with short trailer......cake walk
  5. abyliks
    abyliks Road Train Member
    3,892
    9,100
    May 2, 2010
    ludlow MA
    I have done things with a pup and single axle I don't think I would to with my pickup and tag trailer, takes some gettin used to but you can't put them any where
    double_r Thanks this.
  6. double_r
    double_r Heavy Load Member
    772
    503
    Sep 6, 2008
    Pittsburgh,PA
    Um, no. They back a lot different then a 53' trailer. Takes a lot of getting use to. Hardest part when drivers come from a OTR company and get a local job pulling short trailers is the backing. They take off on you real quick. Takes some time and a lot of practice to get use to one. In all honesty, I would rather pull a 38' or 48' around with a twin screw then pull the 28' pup with a single screw.
  7. 338-Dark-Knights
    154
    20
    Jan 27, 2011
    Canton, GA
    I should find out more tomorrow. Thanks to all for the info so far. I'll keep you posted.
  8. 338-Dark-Knights
    154
    20
    Jan 27, 2011
    Canton, GA
    both class a combos and class b stright trucks, and apperently a variety of both. more news as to what exactly I will be assigned tomorrow.
    bbl for now
  9. Wiggle Wagon
    Wiggle Wagon Light Load Member
    95
    80
    Feb 29, 2012
    Dayton OH
    In 1964, my grandfather was on a Pepsi route with a sideloader. He called in to the company from a gas station and was informed that grandma had just went into labor. He ran to the truck, put her in gear and started speeding to the hospital. He made a hard left and thousands of Pepsi cases dumped all over the road. He had left 3 of the side doors open.:biggrin_25519:
    He went on to work there for 45 more years, eventually retired, and people still give him hell over it.
  10. Allow Me.
    10,679
    12,240
    May 28, 2009
    Rancho Mirage, Ca.
    ANY truck driver worth his salt can back up ANY trailer, ANYWHERE, ANYTIME, in ANY situation. 28', 48', 53', spread axle, whatever. Trust me on this....
  11. 338-Dark-Knights
    154
    20
    Jan 27, 2011
    Canton, GA
    It's not like I have to do it blindfolded guys. GOAL still applies to the places where I grab gear 'R'!
