Was looking for some advice on new truck specs
Currently have 389 c15 accert with 336 and super 40s and fuel mileage is atrocious hence Looking at new. Im lucky to average high 4mpg low 5s
Looking at going with new
w900 x15 565/2050
Deciding between high performance 40s or super 40s
And between 355 or 373 gears
Haul 60-100 k pounds in a roll tight quad, Mostly flat mid west but do west cost with snosqoumie and some b.c
Looking to have it set it for cruising at 70MPH
Thanks for the help
NEW TRUCK gear spec help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by MSQUARED, Apr 10, 2021.
I don't think you can get good fuel mileage with a long hood truck, pulling a quad and running 70mph
Roberts450 and drivinhome Thank this. -
That c15 acert can be made to get better mileage but you'd have to slow down too
Roberts450 Thanks this. -
If fuel mileage is the goal, you've picked pretty much everything wrong to do it with. From truck to weight and speed to operating area.
Roberts450, drivinhome and pavrom Thank this. -
Might try a 579, they are still very nice trucks and mine with a 455hp MX 13 and 3.25s pulling a dump gets around 6.5 doing 100% 80k-85.5k and 8-9.3 while empty Not as nice as a long nose but it rides better then my bosses old 389k did and the sleeper is to die for.
the 510 tune supposidly still gets simular MPG, however i dont have the tune yet so i cant confirm first hand. I do plan to up my 455 to 510 and upgrade my clutch to handle it as soon as i recover from the 5th wheel incident.
Gimme a bit to charge my laptop and ill pull up davie4 to show you the actual engine logs for the last 10k miles.MSQUARED Thanks this. -
But you can't beat long nose square body looks -
Im sure the MPG would be simular to a 579 maybe not as good but likely close. I dont like ISX engines. Heard to many horror stories of them going boom due to pumps. MX engines usually have sensor errors but with mine i pulled and cleaned all my sensors and it fixed 99% of the emissions issues it had from the dealer. Just need to have a davie4 analog tool such as my diesel laptops system to keep em happy. -
Pulling the weight your pulling at 70 your getting good fuel mileage now
Roberts450, drivinhome, lester and 1 other person Thank this.
