new turbo =weak jake
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 379CAT, Apr 30, 2010.
  1. 379CAT
    379CAT Light Load Member
    114
    20
    Feb 10, 2009
    springdale wa
    i put a new B/W 198123 turbo on my truck, and now the jake brake sucks bad, is there a smaller ext housing to put on the turbo that would help my jakes. iv got to get my jake power back this sucks, any idea's?
  3. C16KIWI
    C16KIWI Medium Load Member
    575
    142
    Jun 14, 2008
    New Zealand
    nothing you can do about it sorry, the aftermarket turbo I put on mine has a smaller housing than the stock turbo A/R 1.23 against the stock 1.39 and my jake also lost about 5-8 psi on engine braking.
    Lucky I have a brakesaver and just turned that up a little.
  4. 379CAT
    114
    20
    Feb 10, 2009
    springdale wa
    guess im going to cut a hole in the floor so i can drag my feet on the long grades:biggrin_25512:
  5. josh.c
    josh.c Road Train Member
    1,105
    420
    Feb 22, 2009
    Knoxville, Tn
    I put the same turbo on my truck recently (it was actually a 478120, but I've been told that's just the new part#) and was told beforehand I would loose some jake power. I rarely go west of I35, so I don't have the high mountains and thin air to deal with like you probably do, but I've found that if I grab another half a gear and let the engine run from 17-2100rpm or so instead of 15-1900 like I used to, it seems to work a little better. I also turn the fan on now on long grades, which you probably already do.
  6. power freak
    power freak Light Load Member
    220
    60
    Apr 23, 2009
    Did you ever get your boost up?
  7. 379CAT
    114
    20
    Feb 10, 2009
    springdale wa
    its like 38psi but its running cooler. i dont know if i can live with no jake power. u know how they put exhaust brakes on pickup trucks , could you do somthing like that with a big truck do make more back pressure?
  8. underpsi
    underpsi Road Train Member
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
    You can put a exh brake on if you want, mbe4000 mecedes come with them from factory
  9. 379CAT
    114
    20
    Feb 10, 2009
    springdale wa
    think it would help? or hurt anything
  10. Gambi80
    Gambi80 Medium Load Member
    My Mack has what they call a 'stealth brake' which is an engine brake in conjunction with an exhaust brake (it sounds like a wet fart), most likely because their regular engine brake sucked so bad. It seems to work fairly well, but it's no big block jake. It's weird in that it doesn't build any boost like a normal jake.
    I believe there are stiffer exhaust valve springs in the head, but don't quote me on it. They did this only for a couple years however, mine's a 97 and I think in '98 the different engine series came out and did away with the exhaust brake end of it.
  11. underpsi
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
    You could do it, It will help... not sure if it will be enough for what your looking for. Won't lose power with it or anything
