New turbo whining
Discussion in 'Kenworth Forum' started by tsavory, Oct 12, 2014.
  1. tsavory
    tsavory Road Train Member
    1,910
    1,860
    Jun 4, 2013
    Paoli, IN
    Ok I had my OR7205 turbo go come apart on me the other day I went and bought a T704604-11 from Diesel Injection it supposed to have same internals as the OR7923 with a custom cast house to dissipate tge heat better all seems fine except at approximately 22-24 psi of boost I am hearing a whine in it it dont seem to happen below or above that just right in that range. Anyone have a clue what it maybe?
    I tried spraying a little either near each boot and clamp just to see if it speed up the engine thinking a clamp may be not sealed all the way but nothing.
  3. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    My turbo on my Detroit whined when it was new and took about a month to go away.
  4. tsavory
    1,910
    1,860
    Jun 4, 2013
    Paoli, IN
    Ok so may just be break in
  5. Pipe 40
    Pipe 40 Light Load Member
    209
    359
    Mar 24, 2012
    Toowoomba Queensland
    I had one on a Mack do that didn't go away and they replaced the internals
  6. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,115
    May 19, 2011
    When you posted about that in the other thread, I don't remember you saying anything about cleaning the intake piping and the charge air cooler. It might be possible that you sucked in some debris and have damaged the fins on the new turbo if that's the case.
    tsavory Thanks this.
  7. tsavory
    1,910
    1,860
    Jun 4, 2013
    Paoli, IN
    Ouch I sure hope not will be taking it apart to check it out. when changing did not find any debris in any of the tubing but other than the first little bit did not look real deep.
  8. Oscar the KW
    12,246
    28,115
    May 19, 2011
    Those pieces can go everywhere, real common for them to blow debris back into the air cleaner(s) as well.
  9. tsavory
    1,910
    1,860
    Jun 4, 2013
    Paoli, IN
    Guess I will be up early and tearing it apart to see if an fins are messed up and checking air cleaner and atleast the ports on the cooler dang it I hope nothing went wrong if so guess it gives me a reason to swap it ti a BW sooner rather than later just needed to get going and the DI was close and in stock
  10. rollin coal
    rollin coal Road Train Member
    13,267
    26,725
    Mar 29, 2008
    TN
    I did a thread a couple of weeks ago when my turbo blew up in the garage section. You most definitely need to take all the piping off and apart piece by piece up to the air filter. Throw the air filter away, look inside of it, bet money it has pieces if turbo fins in it. Clean the housing replace with new filter. Clean all those elbows really good, reassemble. Remove hump boots and that piping clean all that. At least shop vac out your CAC on the hot side. Really it's a good idea to remove it and steam clean the oil out. I was told by several people taking all that stuff before the air goes into the turbo apart and making #### sure it was clean was important in order to not destroy the new turbo. After finding all the pieces I now see why. You may end up with another turbo failure on your hands soon.
  11. tsavory
    1,910
    1,860
    Jun 4, 2013
    Paoli, IN
    Took and pulled apart fins look fine no play and took a rag wiped out all tubing I could get off to filter and the CAC did pick up a few chips and kinda a dust. Hope it will last till I get home and can pull everything
