Hello all,
Love this forum. Very informative. Looking to make a career change after 30 years in the printing industry.
Asking for info from Knight drivers. Do trucks come with a mini fridge? How are trucks set up for power?
Most importantly. Do you like your job? Do you get enough miles? Ever had any problem getting paid? I will be training and driving out of Phoenix.
Thanks in advance for your input.
Newbie for Knight
Discussion in 'Questions From New Drivers' started by VikingzRool, Dec 28, 2013.
viking i did work for Knight. they do not come with fridges/invertes/micorwaves or APU's. Volvo with the D13(never derove one) International with eihter the MAXXforce or the Cummins. far ahs HP figure 300 HP or so i dont have an exact number. your top speed is determend by how much you idle. the more you idle, the slower you go
VikingzRool Thanks this. -
viking
i worked for Knight.
If your lucky you'll get an 2010 or older Volvo with the Cummins.
450/475 HP if they're 9-speed
435/460 HP if they're 10-speed
IH's 2009 to 2011 Cummins 455/480 HP 10-speed only
Volvo's 2011 and newer VED13 425/450 HP 10-speed only
Hope this info helps.VikingzRool Thanks this. -
Which truck was your favorite? I think they are making the swiich back to all Volvo.
I think I will be fine in the winter but I'm a big guy and need my a/c in the summer.
I think all Knight Volvos are the 670 sleepers. Correct? The 780 sleepers like mine had space for a fridge. I don't know if the 670's had enough space for one.
Volvo D13's aren't a bad engine. They're pretty efficient. They sip fuel at idle because they are designed to idle at 700 rpm in order to run the "clean idle" cycle. Good for .6-.8 gallons per hour.VikingzRool Thanks this. -
I'm seeing that most are the 670's. If not equiped with apu's. What are acceptable idle times to run the a/c? And still be able to run full speed next day?
Thanks for the info. -
Say hello to Terry and Steve in the training dept. Good luck.VikingzRool Thanks this. -
i forget idle percentages. sory i cant help there
