No a/c
Discussion in 'Ask An Owner Operator' started by Giddy-up13, Jul 21, 2021.
  1. Giddy-up13
    Giddy-up13 Bobtail Member
    4
    99 KW T-600. Replaced entire “heater box” as complete unit. Now compressor clutch will not engage. Ideas?
  3. kwswan
    kwswan Road Train Member
    1,949
    10,349
    Jul 26, 2009
    mcminnville,tn.
    Check fuses & relays.
    Bean Jr. and ibcalm19 Thank this.
  4. reeferwrencher
    reeferwrencher Medium Load Member
    565
    1,486
    Aug 4, 2018
    Is the compressor/clutch new?
  5. Giddy-up13
    4
    New last year. It engages when using jumper wire.
  6. Dale thompson
    5,176
    43,383
    Nov 20, 2013
    commerce twp,mi
    Low on Freon or a bad trinary switch.
    Tug Toy Thanks this.
  7. abyliks
    abyliks Road Train Member
    3,896
    9,120
    May 2, 2010
    ludlow MA
    Did you put guages on it?
    truckdriver31 Thanks this.
  8. w9l
    w9l Medium Load Member
    316
    513
    Oct 12, 2013
    Test your high and low pressure switches. If I am thinking right the high switch will be somewhere in a line on the metal part upfront around compressor line connection or condenser line connection and will have a weatherpak plug with 2 wires unplug it from the round switch and jump the female terminals in the plug with a paperclip. Low pressure will look neatly the same but back around firewall . If it starts with either one put gauge set on and go from there. Actually be good to have gauge set hooked up when testing.
  9. w9l
    316
    513
    Oct 12, 2013
    Come to think of it.... have you already evacuated and recharged system with proper amount of 134a? If you are trying to charge it and compressor won't kick in and let system draw freon, either jump low pressure switch or I usually just run a hot wire to compressor and force clutch to engage while I add another can or two then hook wires back up so that compressor can cycle properly and finish charging. My older KW I have to do this anytime I start from 0 freon. My newer one- so far- will go ahead and short cycle after putting a couple of cans in while in a vac or low psi.
  10. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    they never do. lol
    w9l Thanks this.
  11. Ridgeline
    22,417
    116,640
    What’s a gauge?
    w9l and truckdriver31 Thank this.
