No air to air bag leveler valve
Discussion in 'Kenworth Forum' started by 1957evinrude, Dec 4, 2022.
  1. 1957evinrude
    1957evinrude Bobtail Member
    13
    I have a 2012 kw T 800. There was no air going the the air bag leveler then suddenly started working . Where are the valves located that supplies air to the air bag leveler valve . Could it also be the dump valve in csn not working ?
  3. 1957evinrude
    13
  4. 1957evinrude
    13
  5. beastr123
    beastr123 Road Train Member
    2,853
    23,391
    Jan 2, 2014
    Moose Jaw SK CAN
    It could be the dump valve but if you are in below 30 degree weather I would suspect frost in the line or leveling control valve. the air dryer cannot remove all moisture from your system (especially if the filter is more than 9 months old) and may put moisture into the air tanks. Always drain your tanks when you can park for the night in weather above 40 degrees.
    Bean Jr. Thanks this.
