No air to secondary tank... pressure stays at 50 at idle RPM's... please help!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by MercerDriver, Sep 3, 2010.
  1. MercerDriver
    MercerDriver Light Load Member
    69
    7
    Sep 3, 2010
    Atlanta, GA
    Hi ,
    have a 2003 Freightliner Century truck. Until recently all was well then after one week of being parked, all of a sudden the truck developed an air problem.
    the primary tank gets to 105 psi and waits for the secondary tank to catch up to 105 also (always did this even when truck was new). Then both tanks would go to 125 psi and work the way they should.
    now, the secondary air tank stays at 50 psi at idle RMP's and the primary "waits" for it at about 105 psi. If the RPM's are raised to 1400-1500 then the secondary SLLLOWWWLY starts climbing to 125 psi.
    Anyone know what could be causing this ? Please help . Also, I've heard about bypassing the air dryer but don't know how to do it. Anyone ever done it, and how ?!?!
  3. REDD
    REDD The Legend
    6,237
    4,291
    Jun 29, 2009
    Dueling Banjoville
    It could be anything, including a faulty gauge or sensor. Do you hear air leaking?
    Also bypassing the dryer isn't a smart thing to do. For emergency situations, bypassing will work to get it to a place to have it fixed... If you truely are a Mercer Driver, then bypassing the dryer will give you an automatic failure of you 6 month inspection cycle. Perhaps you have a bad dryer cartridge. I'd change that first before trying to bypass it. They only cost about 30 or 40 dollars & really should be changed on a bi-annual basis if not anually.
  4. Wiseguywireless
    Wiseguywireless Road Train Member
    1,693
    801
    Dec 21, 2007
    Petoskey, MI
    Had a similar problem and it was the Regulator, 23 bucks and I did the labor myself. Fixed
  5. MercerDriver
    69
    7
    Sep 3, 2010
    Atlanta, GA
    where was this regulator located ?! is that the same as a governor ?
  6. MercerDriver
    69
    7
    Sep 3, 2010
    Atlanta, GA
    I know it won't pass inspection, but it will get me home where I can look deeper into the problem. Also, it's not a faulty gauge or sensor. If that would be the case, I would still be able to shift thru all gears, not just the lower ones. I'm by no means a total newbie at mechanics and know some stuff about diagnostics but I need an answer ASAP as I don't want to lay under my truck on the pavement in a rest area that smells like piss.... u know how it is. As far as the cartridge (filter) for the air dryer, might be. But it was changed about a year ago but it's cheap enough to try it.
  7. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    I was going to mention the govenor. The spring could be wore out and it's partially unloading instead of pumping.
    Another possibility is all air compressors have a filtered air inlet. Most big trucks the air inlet is hooked to the engine air filter. Check the filter, it might be dirty or the air inlet tube might have trash in it restricting the air flow to the compressor. Increasing rpm's increases suction so it might be?
  8. wndrwtr
    wndrwtr Medium Load Member
    300
    186
    Mar 12, 2007
    Texas
    or the load check valve located in the head on compressor.
  9. DonL
    DonL Bobtail Member
    10
    Jun 8, 2009
    Creemore, Canada
    If one tank is filling to governor set pressure and the other is not, there is a double check valve between tanks that prevents loss of air from the primary tank if the secondary blows and visa versa, it is likely stuck, drain both tanks then rebuild air and it should reset or replace it
    Doggpoundtrucking Thanks this.
  10. DonL
    DonL Bobtail Member
    10
    Jun 8, 2009
    Creemore, Canada
    If Both tanks are building slow, I have seen carbon buildup in the air line from the compressor to the air drier, the first section, 3 feet or so is metal brade or copper because of the heat, then a brass fitting then regular air line to the drier, that fitting can get plugged with carbon. All compressors pass a bit of oil, combined with the heat it makes a carbon like residue that can be hard as a rock, it can collect in the restricted area of the joiner fitting mentioned above and severly reduce air flow.
  11. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    Thats it! I could not think of the right terminology. you need a unloader kit, it comes with a gasket. comes with new springs & the thing a ma jig's. about 12- 18 bucks.
