I have a 2013 westernstar w4900. I tried another resister and another blower motor and relay also and still no high speed so I guess all that’s left is the switch should be the culprit right? Idk what else to look at!
No blower high speed
Discussion in 'Ask An Owner Operator' started by Perchie15, Sep 5, 2021.
Usually if the resistor is bad you'll lose all speeds EXCEPT high. Sounds like the switch is all that's left. Unless there's something electronic in the circuit controlling it.
feldsforever Thanks this. -
I got it fixed lol switch it is!!! I was trying to Delete this post not sure if we can? I found it after I posted this. Thanks
feldsforever, baha and ProfessionalNoticer Thank this. -
Its better to leave it up for the next person, just so they can see what the fix was.
ProfessionalNoticer Thanks this. -
A simple troubleshooting tip.
If it only runs on high, it is the resistor.
If it only runs on anything but high, it is the switch.
If it doesn't run at all, most likely it is the motor but confirm by a volt meter at the motor leads.feldsforever and Vampire Thank this.
